help need it
Go to solution Solved by JoaoPRSousa,
i see, but why other builders in youtube put about 3 videocards in their pc? its that really nececary?
You really don't need to get 3 GPUs. IF you really want, you can throw in another 980 Ti, yet again, you don't need to.
thanks man, you have pretty much build my pc, i have only one queston, how far im from geting a 4k computer?
You're 700$ away from the 4k$, so if you REALLY want to spend those, get an extra GTX 980 Ti.
"an obvious supporter of privacy"
https://linustechtips.com/topic/403135-help-need-it/page/2/#findComment-5445078
https://linustechtips.com/topic/403135-help-need-it/page/2/#findComment-5445380
