Hey guys, Does using a 1440p or 4k monitor help reduce eye fatigue?
Im not well versed in display, pixle pitch and so on, would be nice to get some advice.
Im currently using a LG29um65 and was thinking of upgrading to a 4k panel later this year.
Thanks in advance for all the info.
https://linustechtips.com/topic/401538-does-4k-reduce-eye-fatigue/
no. using low blue light displays with no flickering does.
SNIP
Technically yes, a high resolution means less pixelation which is better on your eyes
however high resolution = small text on screen = eye strain
something like apples "retina" or 4k Scaled to 1080p for example would be best for the eyes, as on screen text remains the same size, but is higher fidelity
However eye fatigue is also to due with blue light, flickering displays, display distance etc etc etc
In short no, most eye fatigue comes from the blue light of the panel, resolution doesn't really affect it. If the panel is a bad TN and it's fuzzy it can but a LG 29um65 is IPS so that's not the problem.  Try using F.Lux.
Mein Führer... I CAN WALK !!
In short no, most eye fatigue comes from the blue light of the panel, resolution doesn't really affect it. If the panel is a bad TN and fuzzy it can but a LG 29um65 which is IPS so that's not the problem.  Try using F.Lux.
Im already using flux. brightness is lowest.
I know watching videos on the nexus 7 2013 is much better on my eyes than the 2012 model.
i know right, looking at my phone screen(lg g3) feels much more pleasing to the eyes
I dont think anything beyond 320dpi is worth using extra battery to render video...
So i guess for me/my eyes a 4k display with less contrast and less blues and high refresh rate will be the best?
For some wierd reason my wallet is crawling away right now..
Yes but bear in mind 4k, in windows is a bit shitty since it scales everything tiny, so you have to use like 150% scaling, otherwise text is tiny
Especially on 27" and below displays
oh i also tried those "computer glasses" it gave me a headache.
on a side note. Turnip isnt doing too bad! Turnip power is real.
It shouldnt do
Perhaps you need an eye test
It shouldnt do
my thoughts too, if everything strains your eyes you need glasses.   :lol:  :lol:
yeah pretty much!
"doctor it hurts everywhere I touch"
"that's because your finger is broken"
yeah pretty much!
It shouldnt do
Haha, yeah i already did i have a slight 0.5 on one eye diopter correction needed but thats all he said. Had my eyes checked twice actually. Same diagnosis. Im just normally just very sensitive to things.
maybe those glasses were crappy. i can wear glases made for someone else and it probably hurts less that that wierd gaming glasses that had scratches on it from the box
Haha, yeah i already did i have a slight 0.5 diopter correction needed but thats all he said. Had my eyes checked twice actually. Same diagnosis. Im just normally just very sensitive to things.
correction needed means you need glasses.
it does indeed. I find my eyes ache far less than before and I don't get motion sickness from large monitors. win win now! can finally play games for hours and still feel fresh as a daisy
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
