Nvidia 980Ti non reference cooling comparison *w/pics*
ASUS STRIX 980Ti with new Direct CU III
Changes/upgrades/Upside:  Active VRM cooling now added. 3 80mm fans instead of 2 100mm fans. Solderless PCB printing, no sharp points. Glowing logo. 2x 8pin power
Downsides: Still no active cooling or even passive heatsink cooling on memory modules. Direct heat pipe on GPU, no head spreader plate still. Fan housing now plastic, not metal. 90mm fans produce more noise possibly?
MSI Gaming 980Ti Twin Frozr V
Changes/upgrades/Upside: Large 100 twin fans. Passive heatsink/plate cooling on VRM and memory modules. Backplate finally added. Glowing logo. 2x 8pin power
Downsides:  No active cooling on memory or VRM. Plastic fan housing. Backplate does not passively remove heat.
torawje.jpg?1
 fPo9bni.jpg?1
xPMzbZX.jpg?1
 iXD4Rcd.jpg?1
 JQLFG8u.jpg?1
1orxOfd.jpg?1
Gigabyte G1 Gaming 980Ti Windforce 600watt
Changes/upgrades/Upsides:  Triple 80mm fan cooling. HUGE heatsink platform actively cools GPU, memory and VRM heatsinks. All metal fan housing. LED color control. 2x 8pin power. Dual DVI
Downsides: Heavy and long, possibly resulting in more GPU sag. 90mm fans produce more noise.
waes4Xe.jpg?1
 LdG17df.jpg?1
EVGA GTX 980Ti Superclocked ACX 2.0+
Upgrades/changes/upsides:  Included backplate with this model. Passive cooling on VRM and memory. Ball bearing fans. 100m sized fans
Downsides:   Only 1x 8pin 1x6pin power connections, will limit overclocking. Reference PCB board design. Cooling not the greatest. Plastic fan housing
very nice comparison.  I would like to see EVGA on the list.
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
Great job.. This is exactly what i was looking for.. Reassures my decision for the G1 model. When they become available of course.
I dnt want to overtake the post with this question ., but will an i5 4690k bottleneck this card? Pc is only for gaming.
-I'm here to learn-
This gets asked multiple times every day. Everyone knows the forum has a search function right?
And no it won't
People be looking for a reason to flame.
Mine is FINALLY coming today from newegg, I fucking pray it doen'st have coil whine
Mine also arrived today and either the card is DoA or my psu is dead. Already started the RMA process :( back to 1600x900 gaming it is.
yea just buy the Gigabyte GTX970 G1 Gaming.
I feel like you need to mention the Galax GTX 980ti LN2 capable of 2.1 ghz
Everyone flipped out about one little heat pipe on the EVGA 970 not touching the GPU die (even though it didn't matter, still functioned properly and was by-design). Let's see how many people lose their minds because the die only touches 3 of 5 heat pipes on the DCUIII 980Ti... :P
IMO, they all look really well built and well engineered. The EVGA is the only one that concerns me because it doesn't look like there's any direct cooling for the VRMs aside from the fan blowing on them. But that part of the cooler could just be missing from those pics.
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
I liked the all black g1 windforce better than the one with bare metal on the ends. Just looks like a lame cheap attempt at adding some tacky bling.
CPU: Ryzen 7 3700x,  MOBO: ASUS TUF X570 Gaming Pro wifi, CPU cooler: Noctua U12a RAM: Gskill Ripjaws V @3600mhz,  GPU: Asus Tuf RTX OC 3080 PSU: Seasonic Focus GX850 CASE: Lian Li Lancool 2 Mesh Storage: 500 GB Inland Premium M.2,  Sandisk Ultra Plus II 256 GB & 120 GB
Nope, no direct cooling, I updated pics
They are likely just glued on or held with clips, easily removal.
Just added.
Awesome, thanks!  Those thermal images are interesting.  I would not have thought we'd see 105 degrees - its a little troubling actually.  My friend just bought this exact EVGA 980 ti.  Might be worth adding some thermal pads behind the backplate to dissipate some heat!
PC Build
Desk Build
I doubt it will help much if at all as the backplate isn't designed to really pull heat away from the PCB board and then you will need to move a lot of air across it to remove that heat which on a flat surface, won't be very efficient
