Zotac 780 AMP Edition's fans behaving weirdly
veimiK
Hello.
So, for some unreasonable reason, fans on my Zotac 780 start to ramp up for a period of time, and then they go back to normal, as seen here: http://imgur.com/16ljK2w
It is really annoying, especially when watching a movie or gaming, so I'm looking for a fix for it. Anyone knows what might cause this? I've checked all the pins on the cooler/card, they are all fine.
Desktop:
CPU: Ryzen 5 5600x  | Cooler: be quiet! Dark Rock 4 | Motherboard: Gigabyte B550 Aorus Pro AC | RAM: 2x8GB Crucial Ballistix 3200MHz | GPU: Asus GTX 1070 ROG Strix | PSU: ADATA Core Reactor 850W | Case: be quiet! Pure Base 500DX | HDD: Samsung HD502HJ 500GB | SSD: XPG M2 SX8200 Pro 512GB | SSD 2: Crucial MX500 500GB | Microphone: Blue Snowball iCE | Headphones: Corsair HS70 Wireless | Soundcard: Maya U5 5.1 | Speakers: Genius SP-HF1800A | Phone: Samsung Galaxy S10
Secondary Desktop:
CPU: Intel i7 4770k @stock | Cooler: Cooler Master Hyper 212 Evo | Motherboard: Asus Z97-PRO (Wi-Fi AC) | RAM: 2x8GB 1600MHz DDR3 | GPU: Asus GTX 1070 ROG Strix | PSU: OCZ ModXStream Pro 700W | Case: SilentiumPC Aquaris X70W | HDD: Samsung HD502HJ 500GB | SSD : Corsair Force LS 240GB
ASUS ZenBook Pro UX550VD:
CPU: i5-7300HQ | RAM: 8GB DDR4, 2400MHz | GPU: GTX 1050 + Intel HD Graphics 630 | Storage: 512GB M.2 SSD
that's flippin' weird.
Umm maybe try to take the gpu out of the pc and clean everything fan related as good as you can, clean the plugs and everything.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
I always do that as soon as this thing starts happening (if it lasts for more than 5 minutes, and sometimes it does), and well, it fixes it. Rebooting without cleaning it doesn't help though.
Desktop:
Secondary Desktop:
Refresh, anyone?
Desktop:
Secondary Desktop:
Try to send it RMA.
It's clearly not working as it should. I think the chip that takes care of the fan is faulty. Never saw one failing before but everything can break :P
Hopefully Zotac will recognize the problem and fix it.
omg, let's rescue this thread.
What are the temps of the card during that speed increase? Maybe the card is just heating up and trying to cool it with a short ramp up of the fans.
Also: do you have a custom fan curve on your GPU? If not, maybe the stock fan control is going up in steps. So temperatures might reach into a new fan speed step and the card therefore ramps up.
The solution would be to design a custom fan curve in MSI Afterburner. (settings). Something like a flat curve until ~ 60 °C/ 30-40% fanspeed and then a smooth raise to 85 °C/ 100% would be good.
who cares...
