Fallout 3 GOTY wont launch .
Go to solution Solved by AlexGoesHigh,
http://steamcommunity.com/app/22370/discussions/0/828937546147175081/
that should work, this game has a lot of issues running on 7 and above, without some tweaks the game will never launch on 8 and above
Ridska here ,
I got the Fallout 3 GOTY edition on my steam , and i want to start my first play session BUT ,
the game wont launch , i press play in steam and when this shows up ( picture down below ) .
Thanks and stay groovie :D
P.s , trying to mod the game and new to modding .
post-144483-0-16445700-1434892098_thumb.
(⌐■_■)
https://linustechtips.com/topic/390912-fallout-3-goty-wont-launch/
-snip-
Press the play button there? Many Bethesda games have menu's like that before it launches the game
Right click the fallout exe under whatever install directory you put it under and select properties. Click the Compatibility tab. Check box to run as Administrator and with Compatibility mode for WinXP Service Pack 3.
also go to the config file in your documents folder, and make sure that number of cores is set to the actual amount you have.
the config file is called 'config.ini' (iirc)
EDIT: there's also a pretty big 'tweak guide': http://www.tweakguides.com/Fallout3_1.html
When in doubt: C4
this is one of the greatest thing that has happened to me recently, and it happened on this forum, those involved have my eternal gratitude http://linustechtips.com/main/topic/198850-update-alex-got-his-moto-g2-lets-get-a-moto-g-for-alexgoeshigh-unofficial/ :')
i use to have the second best link in the world here, but it died ;_; its a 404 now but it will always be here
Thank you so much for the help :D .
(⌐■_■)
