Asus Strix GTX 970 resolution problem
aXnMaN
i have a friend who has a Asus Strix GTX970 that for some reseason only can display a resolution of 800x600, any of you ever heard of that problem before, and yes he has tried to uninstall and install drivers and stuff like that icon_e_smile.gif
what type of connection are you using on your screen?
VGA is limited to 800x600
i stand corrected
May the light have your back and your ISO low.
I am running VGA at 1080p
well... i stand corrected
might be newer screens or HD ready screens can get more
he was using DVI
he was using DVI
Make sure it's attached to the GPU and not the motherboard.
I think he knows how to connect it the right way  :D  :D  :D  :D
To be fair, this is not an issue you have when you know what you're doing. :P
