I did a few tests with my 7970 running Planetside 2. First test was with a single 1080p display and the second with one 1080p and an idlling 1280x1024 display. With the two displays I hit 86C in-game and 55C idling. With just the 1080p display I hit 79C in-game and 39C idling. The idle temps for both sound about right but the in-game temps are certainly too high. Afterburner shows that:
Core Voltage: stock
Power Limit: +0
Core Clock: 951 (I OCed a bit)
Memory Clock: 1375
Fan Speed: Auto - ranges from 31 (idling) and only goes up to 39 in-game
A while ago I accidently fiddled with the fan speed on Afterburner and my 7970 made some REALLY worrying noises but I quickly shut down without saving any changes and it seemed fine afterwards. I'm just saying this if it might help.
I suspect it's the fan speed why is it only increasing by 8% and what can I do to reduce the temps.
All help is much appreciated.
Thanks.
CPU: Intel Core i7 3770k | Graphics Card: PowerColor 7970 V3 | Motherboard: Gigabyte Z77X-UD4H | HDD: 2TB Seagate Barracuda | Memory: 2x4GB Corsair Vengeance 1600MHz CL9 | PSU: XFX Core Series 550W Black Edition | Case: Corsair 200r | Monitors: LG 23EA63V 23" 1920x1080 IPS 60Hz + Lenovo L1700pC 17" 1280x1024 75Hz
https://linustechtips.com/topic/38972-7970-running-too-hot/
Set your own custom fan curves. Is the reference one?
https://linustechtips.com/topic/38972-7970-running-too-hot/#findComment-501434
That's normal for the dual monitor setup..
<p>Mobo - Asus P9X79 LE ----------- CPU - I7 4930K @ 4.4GHz ------ COOLER - Custom Loop ---------- GPU - R9 290X Crossfire ---------- Ram - 8GB Corsair Vengence Pro @ 1866 --- SSD - Samsung 840 Pro 128GB ------ PSU - Corsair AX 860i ----- Case - Corsair 900D
https://linustechtips.com/topic/38972-7970-running-too-hot/#findComment-501495
I have a PowerColor 7970 V3 non-reference. Can someone recommend a fan curve for me?
https://linustechtips.com/topic/38972-7970-running-too-hot/#findComment-501628
I just did a quick test and I hit 82C  on Planetside 2 with one monitor but my fan was on 55%!
https://linustechtips.com/topic/38972-7970-running-too-hot/#findComment-501665
It possibly just be dust... I'll have a look
https://linustechtips.com/topic/38972-7970-running-too-hot/#findComment-501667
The best thingh you can do is raise the fan speed so that it's still at an acceptable noise level. As you said, It might be dust, but I doubt it. You can also try and change the thermal paste. This will probably grant you a couple of degress.
That said, 82C is not to hot for a graphicscard. You can begin worring if you hit around 90C
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/38972-7970-running-too-hot/#findComment-501689
Best fan curve.... Slooowly increase fan speed until about 70-75c then shoot up to 100% at about 90c. Its ganna be loud, but you have headphones. When under a moderate load, should be pretty quiet.
Change the thermal paste.
https://linustechtips.com/topic/38972-7970-running-too-hot/#findComment-501722
Those temps are fine. But just turn up your fan speed on Afterburner.
System SpecCase: Cooler Master Elite 311 - Mobo: Asus Rampage III Extreme - CPU: Intel Core i7 950 @ 3.5 Ghz - Heatsink/Cooler: Cooler Master Hyper 612, w/ Corsair SP120's - Ram: 16GB Of 1866 Corsair Vengeance - GPU: 2x EVGA GTX 660 Ti's In SLI @ 1015 Mhz - HDD: Seagate Barracuda 2TB - SSD: OCZ Vertex 4 128GB - PSU: Coolmax 800W Semi Modular, 80+ Bronze - OS: Win 7 Ultimate x64.
Peripherals - Monitor: Acer G246HL (TN 24" 1080p LED 60Hz) - Keyboard: Corsair K70 - Mouse: ? - Mouse Mat: Razer Vespula - Headset: Asus Orion.
https://linustechtips.com/topic/38972-7970-running-too-hot/#findComment-502564
What is the ambient temperature of your room/case? My graphics card is idling at 42 degrees on a 1600x900 monitor but its currently very humid and 20 degrees in the UK.
System Specs:
CPU: Ryzen 7 5800X
GPU: Radeon RX 7900 XT
RAM: 32GB 3600MHz
HDD: 1TB Sabrent NVMe -  WD 1TB Black - WD 2TB Green -  WD 4TB Blue
MB: Gigabyte  B550 Gaming X- RGB Disabled
PSU: Corsair RM850x 80 Plus Gold
Case: BeQuiet! Silent Base 801 Black
Cooler: Noctua NH-DH15
https://linustechtips.com/topic/38972-7970-running-too-hot/#findComment-502771
