what block? are you sure you got the one for exactly this card?
https://linustechtips.com/topic/387578-ek-block-does-not-fit/#findComment-5230694
Contact EK. I haven't had to deal with their customer support luckily but I'd imagine they're good considering how great their products are. Maybe they sent the wrong block? If it honestly is the wrong block they should exchange it for the right one or give you a refund if they don't make it, probably minus shipping though. If the standoffs don't line up with your holes then there is something obviously wrong.
  Custom Loop
4790K - Titan X - 16GB Vengeance 1866 - Asus Vii Hero - EVGA G2 850w - Samsung Evo 500gb - Corsair 760T - ROG SWIFT
https://linustechtips.com/topic/387578-ek-block-does-not-fit/#findComment-5231543
I sent a PM to John but for everyone else here, yesterday we released the revised block for the rev. 1.3 PCB's
http://www.ekwb.com/news/604/19/EK-releases-new-block-for-latest-revision-MSI-GeForce-GTX-970/
John should be able to have the correct block for his card soon  :)
https://linustechtips.com/topic/387578-ek-block-does-not-fit/#findComment-5232435
Btw I cannot say enough how amazing it is that EK has a semi/completely official account here. It is an amazing touch for community building and keeping your awesome products on the top of people's lists and thoughts.
I wish more companies did this, the response would be ecstatic.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/387578-ek-block-does-not-fit/#findComment-5237175
Thanks for the kind words!  :)
We do our best to help you guys!
https://linustechtips.com/topic/387578-ek-block-does-not-fit/#findComment-5238458
ek thats great you came out with a 1.3v card wish it was around when i ran into that problem . ek luc can you still use the sli bridge thing between a 1.3 card and a 1.1/2 . since the 1.3 card was longer if i can remember .im looking into getting a second one to sli rather find out before i order the gpu/block
main rig
 corsair 750d | evga 1000w g2 | Gigabyte x99 soc champ | 5820k 4.0GHz | 1tb wd blue | 250gb samsung 840 evo  | Crucial Ballistix Sport XT 16GB 8x2 DDR4-2400 | MSI GTX 970 x2 | monitor Acer B286HK 28" 4K | razor chroma blackwidow  | razor death adder chroma
CENTOS 7 SERVER (PLEX&docker stuff)
NZXT s220 | evga 500w 80+ | AMD FX 8320e | ASUS M5A78L-M/USB3 | 2x8gb non ecc ddr3 WD red 2TBx2 | seagate 160gb microcenter 8gb flashdrive OS
https://linustechtips.com/topic/387578-ek-block-does-not-fit/#findComment-5240233
EK being a bro! I love to see stuff like this. For my next build (which will be my first watercooled one, I promise) I will definitely use EK products for exactly this reason!
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
https://linustechtips.com/topic/387578-ek-block-does-not-fit/#findComment-5240282
I will ask but i'm afraid it might not be possible.
I'll let you know
https://linustechtips.com/topic/387578-ek-block-does-not-fit/#findComment-5242041
I received an answer from Niko and he told me that the EK-FC970 GTX TFX and the EK-FC970 GTX TF5 will align making the use of our Terminal Bridges possible between them!
So my first tought was wrong.  :)
https://linustechtips.com/topic/387578-ek-block-does-not-fit/#findComment-5242967
ok thank you since i have seen pictures on overclock.net of the 2 versions blocks not matching up at all for the link 1/4in-1/2 difference .will be ordering the block soon then thank you
main rig
https://linustechtips.com/topic/387578-ek-block-does-not-fit/#findComment-5247111
Hi again!
You were right about being suspicious  :(
After further checks, you WON'T be able to connect a EK-FC970 GTX TFX and a EK-FC970 GTX TF5 together with a bridge.  They WON'T align.
I'm extremely sorry to have cause any possible issues about with my previous comment  :(
https://linustechtips.com/topic/387578-ek-block-does-not-fit/#findComment-5297098
Hi again!
if its possible can you tell the right people that you cant sli the 2 different size cards together on your cooling config. gives a pop up ect so they know to check there cards before ordering . since thats what made me start searching and found out the hard way
main rig
https://linustechtips.com/topic/387578-ek-block-does-not-fit/#findComment-5299611
