It depends. You can overclock higher, but it won't naturally perform much better. There is GPU boost 2.0 and intel turbo boost, but those won't do anything significant. Also, if it is cooled extremely badly, then it will throttle, killing performance.
It's only going to have an effect if the temperature exceeds the point at which the CPU/GPU begins to throttle (Probably around 90C for Intel).
If your cooling system is half-decent, you shouldn't even approach these temperatures (stock cooler is fine for no overclock).
i5 4670k (can OC to 4.4Ghz) - Hyper 212 evo w/ AC MX2 - XFX Radeon R9 280X8GB ADATA XPG V2 DDR3-1600 - MSI Z87 G41 - Corsair CX600M 600W PSU - 1TB HDD - 120GB SSD
Basically the cooler a part is, the longer it's lifespan will be. I think some graphics cards can perform better the cooler they are.
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
