Help with corsair k70 non rgb
MaximusX
Just got my cosair k70 and figure out how to put on the arm rest.
Desktop 1: CPU: Intel Core i7 4770  GPU: Nvidia Geforce GTX 960 Ram: Crucial DDR3 2x8GB 1600 MHz  Storage: Samsung 850 Evo 250GB and Segate 1TB Hard drive  Desktop 2: CPU: Intel Pentium G3258  GPU: AMD R7 250  Ram: Corsair Vengance DRR3 2x8GB 1600 MHz  Mobo: MSI H81M-E33  PSU: Corsair CX430M  Case: Rosewill MicroAtx Mini Tower
On the bottom there are slots, just line them up.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
Thanks, but are there any ways to keep it from falling down?
Are you supposed to use all four stands while using the wrist rest?
Line them up in a 90 degre angle and it should snap into place on the way back. There are two small retainers or what i should call it that fits in the coutout on the bottom part ot the keyboard.
Ya, keeping it on the desk thats meant to be in under the keyboard.
use whichever you want.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
Do you keep all 4 up?
I personally dont no.
System Specs
Top 2 or none?
Top 2 or none?
I use the top 2 but its all personal preference, experiment and figure out whats most comfortable for you and your setup, my experience isn't at all relevant.
System Specs
How do you take it off?
take it off? ...the feet? ..you dont. Anyways I gotta go to work
System Specs
I assume you're referring to the palm rest that comes with the keyboard. :P If it's anything like the K95 there should be 2 screws that you screws (one on each side) to prevent the palm rest from detaching.
