Posted May 30, 2015 I need a cheap 650/600W PSU that's decent (I don't care if it's not modular, semi-modular). Post recommendations below Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 http://pcpartpicker.com/part/antec-power-supply-hcg620m i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 Corsair CX600MUsed it 2 times now and didn't have any problems with it CPU: Xeon 1230v3 - GPU: GTX 770 - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo Update Plans: Mini ITX this bitch Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 The Cooler Master G650M is cheap and it's a semi modular PSU. Have one myself and I haven't had any problems with it. Case: Corsair 4000D Airflow | PSU: Corsair RM750X V2 | MOBO: ASUS ROG Strix B450-F GAMING | CPU: AMD Ryzen 7 5800X3D | Cooling: CM Masterliquid ML240L RGB | RAM: Ballistix 32GB DDR4 3600MHz CL16 RGB | Storage: Samsung 970 EVO M.2 + Kingston NV2 NVMe | GPU: XFX Radeon RX 6950 XT Speedster MERC 319 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 Corsair CX600M Used it 2 times now and didn't have any problems with it No, it's overpriced, has a midget 3 year warranty and internally is pretty poor compared to other alternatives which are cheaper/the same price i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 No, it's overpriced, has a midget 3 year warranty and internally is pretty poor compared to other alternatives which are cheaper/the same price Like I said, I used it and it serves me well both times, the time I bought it it was about 60€, so not that expensive CPU: Xeon 1230v3 - GPU: GTX 770 - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo Update Plans: Mini ITX this bitch Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 Author The Cooler Master G650M is cheap and it's a semi modular PSU. Have one myself and I haven't had any problems with it. I was thinking of getting this one. Are the cables long enough for a mid-tower case? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 Don't spend more than $45 on the G650M, as for $50 with rebate you can have the HCG-620M which is a better unit (made by Seasonic, the G650M is made by CWT) i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 Author Don't spend more than $45 on the G650M, as for $50 with rebate you can have the HCG-620M which is a better unit (made by Seasonic, the G650M is made by CWT) Yeah but PSU's are really expensive here in Slovenia, the G650M costs around 80 euros or 84 dollars... ._. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 Ah right, what sites are you buying from? i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 Author Ah right, what sites are you buying from? http://www.mlacom.si/cooler-master-g650m-650w Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 http://www.mlacom.si/cooler-master-g650m-650w What rig are you running? Specs? Generally, most single GPU setups will run on a good 500W-520W. i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 For example: http://www.mlacom.si/xfx-ts550-550w-80plus-bronze http://www.mlacom.si/seasonic-s12ii-520-520w i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 Author What rig are you running? Specs? Generally, most single GPU setups will run on a good 500W-520W. mb: msi z97 pc mate gpu: gigabyte gtx970 g1 cpu: i5 4590 ram: corsair vengance low-profile 8gb Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 mb: msi z97 pc mate gpu: gigabyte gtx970 g1 cpu: i5 4590 ram: corsair vengance low-profile 8gb Yes, that will run easily on one of these; For example: http://www.mlacom.si/xfx-ts550-550w-80plus-bronze http://www.mlacom.si/seasonic-s12ii-520-520w i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 Author For example: http://www.mlacom.si/xfx-ts550-550w-80plus-bronze http://www.mlacom.si/seasonic-s12ii-520-520w I'm liking that xfx ts 550, but it's alway better to have a bit more juice and it's not a problem for me to pay a bit more for that. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 I'm liking that xfx ts 550, but it's alway better to have a bit more juice and it's not a problem for me to pay a bit more for that. You will struggle to break 370W on load, that 550W has plenty of headroom i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 Author You will struggle to break 370W on load, that 550W has plenty of headroom Well it does say it's an excellent choice for a gtx 970 card.. maybe I will consider getting this one and save a couple of bucks.. thanks for your recommendation! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 Yeah but PSU's are really expensive here in Slovenia, the G650M costs around 80 euros or 84 dollars... ._. I'm getting the same PSU in half a month, and I recommend you to buy from a german store http://mindfactory.de, because its the cheapest store in EU and the shipping cost is low (19.99€ per package to Slovenia, but note, that the case its a package on its own, so if your ordering full build, including the case, you will pay 2x shipping). The G650M is 60€ there: http://www.mindfactory.de/product_info.php/650-Watt-CoolerMaster-G650M-Modular-80--Bronze_937513.html. Tam imajo res nizke cene. Splača se pogledat. My Rig: http://pcpartpicker.com/p/gRPWTW Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 I was thinking of getting this one. Are the cables long enough for a mid-tower case? Yes, they are. I have a Corsair Obsidian 450D (mid-tower), and they fit perfect in this case. No problem with them being too short. Case: Corsair 4000D Airflow | PSU: Corsair RM750X V2 | MOBO: ASUS ROG Strix B450-F GAMING | CPU: AMD Ryzen 7 5800X3D | Cooling: CM Masterliquid ML240L RGB | RAM: Ballistix 32GB DDR4 3600MHz CL16 RGB | Storage: Samsung 970 EVO M.2 + Kingston NV2 NVMe | GPU: XFX Radeon RX 6950 XT Speedster MERC 319 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 30, 2015 Well it does say it's an excellent choice for a gtx 970 card.. maybe I will consider getting this one and save a couple of bucks.. thanks for your recommendation! The XFX TS550 is a good choice if you're ordering from only that specific site. However as stated above mindfactory.de has better prices and selection, and for that, this would be a better choice for the money then TS550 http://www.mindfactory.de/product_info.php/550-Watt-Super-Flower-Golden-Green-HX-Non-Modular-80--Gold_944620.html "Rawr XD" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
