TV vs Monitor
Go to solution Solved by Ice_Stormz,
Hey UnknownIndividual,
I've used a 32" Dynex TV for gaming. I've used it with my PS4 and a steam machine.
There was no unnecessary lag but the biggest concern was latency was roughly 1 second. There was the
occasional death due to response times but nothing TOO major. If you can live with dying a couple extra times
for the extra screen real estate, then I highly recommend going for it!
Hope this helps, and let me know if you have any more questions.
You can get a number of 1080p 60Hz monitors on the cheap ~$200. But using a TV isn't that bad.
The "lag" only matters if you're pretending to be a pro CS:GO player.
Git Gud.
So I am trying to save some money and use my Toshiba 32inch HDTV as a monitor for use and gaming but I heard that it would lag. Can anybody help on if I should use the tv to save money?
It will look pretty terrible 32" up close at 1080p, but it should work fine, it wont "lag" but there will be higher latency than a normal monitor
if you are not gaming competitively it will be ok - but I would save up and get a proper monitor
So should I use my tv for now then save my money to buy a monitor later?
Dude, playing CSGO competitively isn't pretending to be a pro.
Yeah. Monitors make a huge difference.
So would it impact me if I'm playing a game such as GTA V?
So I am trying to save some money and use my Toshiba 32inch HDTV as a monitor for use and gaming but I heard that it would lag. Can anybody help on if I should use the tv to save money? http://www.bestbuy.com/site/toshiba-l2400u-32-1080p-led-lcd-tv-169-gunmetal/1312673487.p?id=mp1312673487&skuId=1312673487
I use a  1080p tv for my monitor and its fine, took forever to get it to look good but yeah part from that it is fine
I did a thing once and it was awsome: https://soundcloud.com/jamese666/junkhead-cover-with-vocals
Not for GTA, no. ALthough game mode would be suggested if available.
As has been said before...the ms of "lag" between a run of the mill display and a display of 1ms is only going to matter to those in competitive gaming...if you are not playing games competitively for cash, you are in no way going to be effected by a slightly longer display response time.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
Forgot to mention it has game mode sorry. I am just trying to switch from Xbox 360 to PC
using a 40" tv 1080p , sitting 2 ft away
for a whole year i am totally fine with it, but 4k is soo much better at this size.
its night and day
edit: the tv should be fine, i experience no unreasonable lag.
its night and day
It'll look better if it's a 21" since it has better PPI and it'll be more clearer. Try sitting directly in front of let's say, a 50" TV. You'll probably be able to see the RGB pixels in the TV.
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
Best Regards
Karan M.
well you get used to it after a year. the better ppi of my 24" monitor doesn't matter if i can barely see it from the same distance.
i don't have amazing eye sight. from a reasonable distance like when i lean back in my chair, i am unable to notice the rbg subpixels (its 4')
my plan is to go to 4k because at this size the extra pixels help alot. for 500$ you can upgrade to a 50" 4k display (http://www.amazon.com/Sceptre-U508CV-UMK-50-Inch-Glass-Ultra/dp/B00S4HI7CO/ref=sr_1_2?s=tv) and ain't that just fine.
big screens are a lot better for watching movies on no doubt.
