ANTEC VSP5000, fans, airflow
Solved by LogicalDrm,
Its pretty new case and Antec isn't at the top of case markets anymore. Seems decent, at least for cooling options. Fan placement is up to you. More exhaust fans means more dust inside the case but temps are bit better. You could change it to more common 2 intakes, 1 rear exhaust setup just by using the included fans. You can always buy more fans later if temps are bad for your liking.
Featured Topics
Voy ·
Posted in Programs, Apps and Websites1 -
gamingandblaming ·
Posted in Cooling2 -
4
SuperFlower ·
Posted in Displays1 -
Prehistoric ·
Posted in CPUs, Motherboards, and Memory2
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
