Mouse is weired how to fix ?!
Solved by ofr057,
if your mouse is old it might have some gunk in it, pull it apart and use some electronic cleaner solvent (you get it in a spray can) spray it on the switches then use them abit.
use a q tip to wipe any off
Featured Topics
awdasdwasdfgeasdf ·
2
1
9
andej ·
Posted in Networking1 -
HALLOFFAMEGALAXFAN900 ·
Posted in Programs, Apps and Websites1 -
IceTeaSRB ·
Posted in New Builds and Planning1 -
bal723 ·
Posted in Troubleshooting4 -
Sychicyuto ·
Posted in New Builds and Planning2 -
Sasha93 ·
Posted in Graphics Cards2
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
