I have a internet bottleneck Help!
Go to solution Solved by minibois,
Can't get higher then 4.5 Mbps in total.
That is because that download site measure Mb (megabit) while Steam measure it in MB (megabyte).
1 megabyte = 8 megabits.
So 25Mb = 3,2MB.
So nothing is wrong.
Hello I have a internet bottleneck.
I can't find the bottleneck.
Can anybody Help me?
I have a 25 Mbps Down and 10 Mbps up.
I'm with bell.
post-34836-0-90191500-1432018091_thumb.p
My motherboard (Gigabyte GA-970A-D3P) I has a Realtek® GbE LAN chip (10/100/1000 Mbit)
post-34836-0-90161600-1432018093_thumb.p
I have a CAT 6 Ethernet Cable connecting my pc to the router(Bell Fibe Sagemcom Router) with 4 Eth 10/100/1000 Base-T.
post-34836-0-70279400-1432020131_thumb.j
Can anybody Help me? Thanks
I cant get Higher then 3 Mbps on steam
Edited by DCwars12
https://linustechtips.com/topic/369463-i-have-a-internet-bottleneck-help/
What makes you think you have a bottleneck?
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
>.> 25gbps down?
10 gbps up?
Dear lord what sort of internet infrastructure do you have? Bell doesn't have a consumer 25gbps download package
They do have a 25mbps down and 10mbps up, I think ye got your details mixed up mate.
Their fastest package is only 175mbps download.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
-snip-
It should be correct.
25Gbps internet plans don't exist, 25 Mbps does.
please check that you have 25Mbps, not 25Gbps.
What bottleneck? what issue are you having
So let me see if I have this right, on another computer you get 25mbps and on this computer you can only get 4.5mbps using the same test?
CPU: 6600K @ 4.6Ghz | COOLER: H100i GTX | MOBO: Asus Z170 AR | GPU: EVGA GTX 1080 Ti Hybrid | RAM: G.Skill Trident Z RGB 16GB |
CASE: Corsair 760T | PSU: Corsair RM750x | STORAGE: Samsung 850 EVO 250GB & Seagate 2TB | KEYBOARD: K70 RGB | MOUSE: Deathadder Elite
So 25Mb = 3,2MB.
You confused MB w/ Mb.
25 / 8 = 3.xx MBps
You're getting your advertised speed.
| CPU: Ryzen 5 3600 | MoBo: MSI B450 Tomahawk Max | RAM: T-Force Delta RGB (2x8) 16GB 3200MHz (Black) | GPU: Gigabyte GTX 1660 Ti OC | Case: NZXT H500 (Black) | HDD: WD Black 2TB + Seagate Barracuda 4TB | SSD: Crucial MX500 2TB | PSU: Seasonic GX-550 | Monitor: 3x Asus VC239H |
I don't see any bottle neck.
you say your getting only 4Mbps but the test picture shows 25down 10up.
If you want any better the best I've found so far is
www.mediacomcable.com you pay $80 per month for 150 down 10-20 up depending on which of the highest priced ones you buy.
And maybe upgrading to something like the Asus wifi adapter for the best Wifi you can get if you wanna say screw the Ethernet cable
If so try this. It has up to 1Gbps so you should never have any issue except your own routers range
http://www.amazon.com/Dual-Band-Wireless-AC1900-PCI-E-Adapter-PCE-AC68/dp/B00F42V83C/ref=sr_1_2?ie=UTF8&qid=1432029045&sr=8-2&keywords=asus+wifi+adapter
You have 25Mbps down and 10Mbps Up, not Gbps. I can't see a bottleneck, other than the speed of the network, technically.
Agreed. there is no problem here. alot of the time you get only as much as you can divie up amongst the household. so you are getting a good speed. and NEVER USE THE TERM BOTTLENECK again until you understand what it means... <_<
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
Run speed tests from different devices call isp and email screen shots. They should fix it
My rig:
CPU: i7 4790k @4.5ghz (1.165v) COOLER: Hyper 212 Evo  MOBO: Asus Maximus VI EXTREME   RAM: 8GB Kingston FURY @1866 Mhz   GPU: ASUS STRIX GTX 970 DUAL SLI   PSU: Corsair HX750   CASE: NZXT Phantom 830 HDD: WD Black 3TB SSD: Samsung 840 EVO 256Gb
