Gelid Tranquillo, Scythe Katana 4, Hyper T4. In order.
I need a cooler to overclock the 4690k to around 4.5 that isn't as big as hyper 212 evo which is 159 mm, I'm looking for something around 155 mm.
I'd appreciate if you mention more than one model and as cheap as possible .
It's gonna be hard to get something smaller that'll take your chip to 4.5ghz. Especially with good temps during stressing. Now if your chip is a good one and require little volts you might be able to, but it's pretty much a gamble
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
Well, 4.5 more or less,, thing is the case can't handle hyper 212 without me bending the case , but a 155 mm would work
Was the Hyper 212 Evo able to keep your particular chip under control at 4.5 Ghz? That's a pretty big overclock and unless you have a golden sample I seriously doubt a smaller air cooler will be able to keep temps at a level I'd call respectable.
You either have to try and find a way to get a monster low profile cooler (I can't think of any) or far more likely pay up the cash for something better.
I didn't do my build yet, I just know that cooler doesen't fit based on user feedbacks in the case I'll get
I would go with the noctua nh u12s
The NH-u12s is just as tall as the 212 Evo.
What case?
Where are you shopping/located?
What case?
It was called Segotep Fighter C, but I just changed the list to Segotep Warship Evo black and this one supports 165mm cooler , heh :) .
One problem is that with the Evo 212, and Asrock z97 pro3, corsair vengeance dimms might not fit
That's because Vengeance ram is stupid. Get ram that isn't ridiculously and unnecessarily tall.
At 145mm, the Cryorig H7 is your answer.
Intel Core i7-5930K | Noctua NH-D15S | ASUS X99-M WS | 32GB (4 x 8GB) G.Skill Ripjaws V 2666MHz | MSI GeForce GTX 980 Ti Gaming 6G | Samsung 850 Pro 512GB | Seasonic 660XP2 | Phanteks Enthoo EVOLV
LG 34UM95-P w/ Ergotron MX  | O2/ODAC | Audioengine A5+ w/ AS8 | Sennheiser HD 598 | Ducky Shine 3 | Cooler Master Storm Spawn
where can I get this? Prices not available on PC Part Picker.. Looks good I have the vengeance ram as well but with a AMD3+ Socket. and I think this fits the bill
Edit: I'm in Canada. Seems like its not sold here :(
CPU: AMD FX-8350 4.0GHz 8-Core Processor  Motherboard: Asus M5A99FX PRO R2.0  Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory
Storage: Western Digital Caviar Blue 1TB 7200RPM Video Card: Zotac GTX 970 4GB Video Card
Case: Corsair Graphite 230T Black  Power Supply: Corsair CX 750W 80+ Bronze
They're available on Newegg for $32.50. The price will probably go up to $34.50 tomorrow, as it's currently on sale. Link: http://www.newegg.com/Product/Product.aspx?Item=9SIA4UF2DZ6565
EDIT: Oh, you're in Canada. Don't know about distributors in Canada, unfortunately.
Croyrig H5. A monster CPU cooler for 50$, cools the shit out of my 4790k.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
