Need help with a pc
Go to solution Solved by WoodenMarker,
around 750€
This is one of those weird moments when the 960 is a better value than the 290.
How's this look instead?
Im sortof trying to get into the world of pc gaming, so im looking for a pc what can run the recent AAA titles and maybe stream games such as csgo (Internet speed not in consideration). Im probably gonna go with a 1080p monitor.
Here is are the pieces - http://pcpartpicker.com/p/YcPN7P
Thanks in advance
Toenail
https://linustechtips.com/topic/366024-need-help-with-a-pc/
Thanks in advance
Toenail
The h81 chipset needs a BIOS update to work with Haswell refresh CPUs. Either get a different motherboard or switch to the i5-4440 (Same thing pretty much except non-refresh) just to be safe. I also recommend this RAM: http://pcpartpicker.com/part/gskill-memory-f314900cl8d8gbxm since it costs about the same, has a lower latency, higher clock speed, and has the same voltage.
My personal changes: http://pcpartpicker.com/p/kPDyBm
EDIT: Toshiba makes hard drives?...
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4957838
Get a bigger, quality branded PSU.
The PSU is the only part that can single-handedly kill your entire system if it fails, And i would not recommend a 550, You dont know what the future holds for wattage.
Edited by Johannes_Lazor
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4957857
No case?
Get another case and a quality brand PSU.
The PSu is the only part that can single-handedly kill your entire system if it fails.
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.99 @ Newegg)
The Capstone is much better than the cx600m.
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4957861
Capstone mops the floor with CX.
"Rawr XD"
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4957890
Yeah, seems pretty good to me.
Only some minor changes I would personally make, but it looks very good!
Toshiba, Seagate, WD and Hitachi are like the main HDD manufacturers
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4957900
Looks good aside from CPU. I would get a non-refresh chip like the i5-4440 to prevent possibly not having a new enough BIOS version out of the box.
Also you could save some money with this mobo http://pcpartpicker.com/part/msi-motherboard-h81me34
"Rawr XD"
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4957903
I thought Toshiba just made disk drives haha. I've actually never seen a Toshiba hard drive
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4957910
Thanks in advance
Toenail
You are going to need a bigger psu for the 290. The 290. Is a great choice of gpu, has that sweet spot of price and performance.
I would reccomend at least a 650w for a 290 to be safe. Being that they draw, 400w under load. If you ever plan to overclock, I would go 750w instead.
A h97 board will be better than a h81. The h81 will require a bios update, and it is generally better to get newer things.
Finally, throw an SSD in there. They make general usage SO much faster, and a pleasant experience. Just make sure to load your OS onto it. 120/128gb shoukd suffice.
Enjoy the build! :D
Quote my post if you need me to respond.
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4957915
-snip-
Your quotes are kinda broken :Pnvm.
Kinda agree with your PSU talk, but I think 650W for an OC'ed 290X should be fine too
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4957934
Not if he upgrades to an unlocked processor and OCs.
Always better safe than sorry.
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4957955
The Capstone 550 is already more than enough. After all, it's less than ~400w under load--meaning it shouldn't draw more than that and this is with an oc'ed 3960x: http://www.guru3d.com/articles-pages/radeon-r9-290-review-benchmarks,10.html
Anything more is already overkill.
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4957956
Get a bigger, quality branded PSU.The PSU is the only part that can single-handedly kill your entire system if it fails, And i would not recommend a 550, You dont know what the future holds for wattage. Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.99 @ Newegg)
Well an AIO COULD single handedly kill the entire system but it is very rare for them to leak, much less destroy everything.
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4958040
Get 1x8GB memory if you are sticking with that motherboard. there is no noticeable speed difference and you have the chance of going 16GB in the future.
That R9 290 is expensive, you can get a R9 290X or GTX 970 for that money.
Well i live in Estonia and im looking to buy the pc parts from here, so the prices on newegg or places like that dont really go for me.
the 970 is 50 euros more expensive and the 290x about 80 euros.
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4958752
Are chieftec PSU's any good or are they complete trash?
Second one.
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4959409
What about corsair atx 2.31 vs series 650w for the r9 290
The VS series isn't good.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4961430
Fantastic build. No money wasted anywhere for no reason.
Try to get an IPS monitor tho, with as high as refresh rate you can. There some 1080p IPS`s with 72 or 75 hz if you look around.
I personally recommend a 21:9 IPS of at least 29" or higher. Those will make you ruin your life with gaming addiction.
If you can afford the LG 29um67 is a widescreen IPS with 75hz and freesync (which will work with your 290 and blow your fucking mind)
https://linustechtips.com/topic/366024-need-help-with-a-pc/#findComment-4962032
