Running headphones too loud damages them?
By
Cookybiscuit
in Audio
in Audio
Solved by gilm0re3,
I would recommend going to your nearest goodwill or something like that and picking up a set of cheap Dell speakers or something similar for 10 bucks or so. It just isn't worth risking breaking a set of expensive headphones just so you can have audio when not directly next to your pc.
3
1
INotPablo ·
Posted in CPUs, Motherboards, and Memory5 -
4
1
2
