PS3/4 or X360/1 controller for Skyrim/The Witcher 3
Solved by dalekphalm,
Oh don't use a controller for Skyrim, it completely ruins gameplay.
While it might for you, one of the amazing benefits of PC Gaming is choice! (You know, some of that BS that #PCMR always goes on about)
So while it might be better for you, perhaps @Wadu436 prefers to use a controller for it. Given that I've personally played Skyrim on both the XBox 360 as well as PC, I can personally verify that the controller does indeed work quite well. I personally prefer Keyboard + Mouse more - especially if you're doing any archery, but aside from Archery, everything else is super easy to do with a controller.
@Wadu436 I'd suggest the XBox 360 (Or XBox One) controller, since, in my experience, it's far superior to the PS3/4 controller.
