PS4 Cooling Issues?
HK6
Ever since Sony first showed the PS4, I have been wondering how they plan to cool the system. It clearly has a lot of ventilation on the rear, and a little bit on the sides, but is that enough? The console seems almost too thin to have a CPU-mounted fan, and even if it did, it would just be blowing against the side of the console. I am no cooling specialist, but it just seems like it might end up being a problem.
The PS3 had a single fan that cooled both the CPU and GPU.
that thing is like 10cm and its a blower fan (we have lots of dead ps3 fats in work).oh also xbox has same system 6-8cm ball bearing fan cooling down everything
i would say why take the risk ? just give it a beast overkill cooler since consoles never ran silent
Passive cooling? Maybe with a few small fans around the console?
Still probably better than the original Xbox 360's cooling. RROD here, RROD there, RROD everywhere. They really EA'd that one.
This is my Lightsaber.          {[=]////]"[¬'/\Y/#####################################
This is my other Lightsaber. (T!!!!!!!T=:"|[\#####################################  #killedmywife
I'm fairly sure that they testet it to see if whatever they have, is enough :P
But there is always that guy who puts it in a non ventilated space inbetween a sandwhich of heat producing electronics are goes :
"Bruh i payed 400 dollars fo dis, naw whutta im sayin? And ya'll can't even make something legit homie? #SWAG #YOLO #PS4SUCKSMYBALLZ #OBLEYZ, gimme back dat cash homie."
And then a week later wonders why it broke.
Just by guessing I'd assume there is an intake and exhaust on the back. The air will be channeled from one side to the other passing over the heat sinks. But until people open it up WHO KNOWS?? I wish they did open it up so we could have a look at it though see what the heat sinks look like.
        Sager NP9370EM - I7 3630QM - 680m 1045Mhz - 8gb 1600mhz ram - 240gb msata 750gb hdd
The PS3 models also have more room to work with inside. I'm curious as to what size fan you could reasonably get into the new form factor.
My 360 Slim runs really quiet. Some tech sites have been saying that the Xbox One is even quieter.
Could work, but they would probably be smaller fans that would run at a higher RPM.
Laptops is even thinner, so I can only imagine that it have atleast a decent sized heatsink :)
I would really hope they have tested it. Very true. I don't think I know of a laptop with quite the same internals that doesn't run hot/loudly though.
I don't think anything will be as bad as the original 360s. Whoever thought that this would be a good way to cool the system must have been doing something...
i also own and 360 slim and it gets hot(yes i know this one can run hotter than previous ones) even though i replaced thermal paste on cpu-gpu package with as5 after playing state of decay (which is hardcore on both cpu and gpu) the temps peak out at 65 degrees and fan running on %70 ,ps mine was banned on xbl so i rgh'ed it thats how i check the in game temps and fan speeds
What you just said makes no sense. Please brief me in what you were trying to contribute to this in a way people like me can understand
msi h77ma g43
i5 3470
Coolermaster hyper 212 evo push+pull
Powercolor 7950 pcs+ @1100 mhz core 1400mhz mem
Coolermaster haf 912 advanced 120mm rear, 200mm top 200mm front
Corsair vengeance 2x4gb 1600 MHZ
Windows 8 64bit
Silverstone essentials 500w ST50F-ES
Samsung dvd drive
2x 250GB Hitachi RAID0
Seagate Barracuda 2tb
LG IPS235p
Razer Blackwidow
Razer Deathadder
It doesn't matter how you cool it, there will always be some braindead swaggot who will screw it up.
Yeah, which is part of my concern. A current-gen console with far lower specs than the PS4 or Xbox One is running hot with ventilation on the top, bottom, both sides, and the rear. I can't imagine what temperatures inside the PS4 will be like in normal situations, let alone in the heat of warmer environments.
but if it's intended as a Home Theater system,and is marketed as something that basically needs no maintenance....it shouldn't matter where you put it.....no maint. means it should just work.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
the new consoles TDP should me moderately close to the first revision of the XB 360 and the PS3,because they both had ~210 watts power consumption.
the new console has a APU,which I bet will take ~170-200 watts.
why?the current APUs take 100 watts for an 8670D,it performs slightly below an Nvidia GT 640.
and the power consumption for the HD 7850 is 115 max.
so I would say that the cpu will probably take 65-95 watts,and the gpu will take 103-115.
I have an original xbox xenon and it still runs, i modified it to fit in a pc case which never happened but seriously the cooling design wasnt that bad (heatsinks needed to be bigger but whatever) and there wouldnt of been as many problems if the went through with thier first idea of mounting a 70mm fan as an intake (notice the 3 pin fan header?)
Im guessing (and if it was me) they will have a copper based circular heatsink over the apu around 110mm diameter with a 90mm impeller "blower" fan inside it taking air in from above and blowing it through a duct through the powersupply (like with the ps3) and out the back, air wil come in through the sides through a duct and be drawn into the impeller..
the other option is EXACTLY what they did with ps3slim with a blower blowing through a finned array (maybe with a heatpipe going to the 7790 gpu IF thats on  aseperate pcb...) and again air passing over the back..
If you have a good design that works you stick to it and now theyre all box's and have realised that the sloped domed thing is dumb they have more surface area on the back/sides the get airflow, xbox one will be exactly the same.
FWIW a very de-clocked and undervolted apu (im still wondering if the "8 core" thing is just a marketing twisting of definition) wont develop much heat, im guessing each machine will be around 150w from the wall gaming, maybe less..
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
I've maintained my Fat PS3, and more recently my Slim PS3 and i have to say the engineers at sony knows their stuff. The original PS3 was a massive blade heatsink connected by really long copper pies going all over the back of the system. It was really cool design but a bit large. Recently I replaced my Slim's thermal paste and i saw the heatsink shrink significantly with a standard fin array with both the gpu and cpu in close proximity sharing it with a copper heatpipe. what blew my mind was that the air being drawn into the array exhausted in only one direction through a compact power supply so that it would get airflow as well.
With PS4 coming out, i really think that they've managed to work some engineering magic to do something that would cool well being that the power supply is going to be internal.
I am now wondering If the Xbox one is going to have an internal or external power adapter. That was a huge perk to the PS3. Not that much bigger and only had to carry a cord and the system not a brick that stood out, on top of the large system that was super loud.
Pretty sure it will be plenty. At the end of the day, its just an APU clocked quite low.
guys, we'll find out on release day when some people open it up to see the inside.
Delltopia
Case & Mobo: Stock Dell Optiplex 7010, CPU: i5 3470, RAM: 16gb 1333 DDR3 (1x8gb Corsair Vengence, 2x4gb Random), GPU: Diamond Radeon HD 7970,
PSU: EVGA GQ 650W, SSD: Kingston v300 128gb (OS), HDD: 700gb Seagate 7200rpm (Storage)
The ps2 only had 1 fan in the back(fat version) and it never overheated. But with the newer smaller form factor they may steal cooling methods from laptops like the MacBook air and other Ultrabooks. Another option would be to put in flat mounted fans attached to the top and bottom of the system to cool the overall components.
Does not having a second parenthesis around something bother anyone else as much as it does me? (Like if this statement was missing a second side)
PS3 slim heatsink was pretty small, and after I changed the thermal paste on mine, I could never hear the fan.
With the newer more power efficient chips, I don't think cooling should be a problem.
sony-ps3-playstation-3-slim-cech2501a-25
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
The PS4 Won't have any problems if sony would use a couple of noctua fans ;)
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
