Dual monitors - DP input best conversion method.
No wonder I was struggling to find a 'DisplayPort splitter'. :lol:
Are you able to recommend a decent one?
Also, after having a quick look, none of the MST hubs I saw explicitly mentioned refresh rates greater than 60hz (either at all or at 1440p); is this an unreasonable expectation from a single 'DisplayPort output'?
Thanks for pointing out that my solution #2, above, will not work.
This reminds me of the classic story of an owner of a Fish and Chips shop ordering a new sign. The sign arrives but it reads, 'FishandChips'. The owner says, 'There needs to be more space between Fish and and and and and Chips.'
I haven't used any hubs personally, so I can't recommend any.
As far as I know you should be able to do anything that DisplayPort supports through an MST hub. The capabilities go up to 4x 1080p 60Hz, 2x 1080p 144Hz, 2x 1440p 60Hz, 1x 1440p 144Hz, or 1x 2160p 60Hz. Any of those configurations should work through a hub.
