Nitrogen Gas Phase Change system 2002 Rebuild
proteus262
Hey Modders, I built this rig in 2002 and ran it solid for about 5 years.  I had to storage it for the last few years, but I just started a rebuild.  I got amazing temps from it and so far everything is stable and very reliable. I'll try to add a brief description of the build.
The most of the build sits inside a PVC pipe, I pump Nitrogen gas in to displace the regular air and to get rid of the moister content inside.  I also have a few desiccant packs inside to help minimized any moister build up through any small cracks or holes I have in the containment. Once I do a purge I start up the phase change, it takes about 10minutes to get it to my operating temperature. The phase change is on a threshold of between -3c and +12c.  I’ll end up tweaking that eventually to -5c to +10c.  But need to ensure I can displace the heat properly.  As a side note the evaporator goes to -15c in order to move the heat and get to these temps.  The hard drives and power supply all live outside the containment.  I have a 120mm AC fan that circulates the chilled nitrogen within the containment.
The phase change cycle is about 5minutes on and then 10-15minutes off depending on the load.
I approached a professional company to help me get the evaporator and the motor properly installed.
The current system I have in it is the following. Please note I had to cheap out on the ram and use an existing graphics card.  I plan to upgrade both in the near future.
Intel Core i7-4790K Processor
Asus SABERTOOTH Z97 MARK 2Motherboard
2x HyperX FURY Black 8GB DDR3-1600MHz CL10 Dual Channel Kit (2x 4GB)
Nvidia GTX 660
The whole rig runs well, dipping the CPU, motherboard, ram and video card below -0 at idle. I’ll try to do some overclocking right away in the next few weeks see what I can achieve. One of the best features is no dust build up so the system is pretty clean with very little maintenance or upkeep. Every now and then I replenish the Nitrogen Gas to displace the air.
Let me know what you think and I’ll try to answer any questions.
Oh the photos were taken at the end of a late night, so yes the table is covered in stuff and I still need to fix it up… a lot…. a lot....
post-225150-0-40496000-1430191670_thumb.
post-225150-0-94162400-1430191672_thumb.
post-225150-0-66056500-1430191717_thumb.
Woah. That's like something you'd see in an Iron Man movie!
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
Nvidia GTX 660
That's amazing. How much did it cost?
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
Well this is something I've not seen in a long while, but looks really awesome!  :D
The total cost for the unit was around $3000, not including the computer system. As for how loud it is, it's like having a fridge running in the background not really that loud.
