PSU Help
Solved by quan289,
is there a difference between the EVGA Supernova 750w G1 and G2? or do they work same?
G1 = FSP Aurum
G2 = Super Flower Leadex.
G1 is a low cost design that offer high efficiency and full modularity. However, it is vastly inferior to the higher-end G2 in respect to build quality / design, electrical performance, and noise output. I would definitely get the G2 over the G1.
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
