Posted April 14, 2015 Should I stick with my stock cooler which comes with the Intel Core i5-4690 3.5GHz Quad-Core Processor or should I buy the 212 EVO? A friend told me I should stick with the stock unless I'm overclocking. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 14, 2015 Stock cooler if non K series, you can't overclock it anyway. But if you get the K series (4690K) get the 212 EVO. Where I hang out: The Garage - Car Enthusiast Club My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT) PC Specs Indonesia CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970 Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter Australia CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 14, 2015 if you are gunna overclock. yes 3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C If you follow these 3 tips you should have a blast. i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 14, 2015 Depends. If you want or need your pc to be quieter, go for an aftermarket cooler. The stock cooler is going to be very loud. If noise level does not worry you, the stock cooler should do fine. Temps under load can be quite high but nothing to worry about. Cpu:i5-4690k Gpu:r9 280x with some other things Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 14, 2015 You don't NEED it, but you certainly can get one for lower temperatures when under load PC Build: Project Re-Define | Project Mochii | Personal Rig v3 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 14, 2015 if you are gunna overclock. yes He's got a 4690. And I dont think he would be going for blck overclocking Cpu:i5-4690k Gpu:r9 280x with some other things Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 14, 2015 Author If I don't get the EVO I can get a the k version. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 14, 2015 If I don't get the EVO I can get a the k version. ??? No, if you get the K series then you should get aftermarket cooler such as the Hyper 212 EVO as it's more capable to keep your CPU cooled while overclocked. Where I hang out: The Garage - Car Enthusiast Club My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT) PC Specs Indonesia CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970 Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter Australia CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 14, 2015 Author Ok. I'll stick with what I have then. Thanks m8ts Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 14, 2015 After market no matter what unless your not gaming. the Intel stock cooler is really loud when gaming on it. The Hyper 212 EVO is the best price to performance CPU cooler out there and with its amazing temps! ask anyone. Its the best Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 14, 2015 ???Pretty sure the OP is referring to budget constraints.If I don't get the EVO I can get a the k version.You need to quote a post or tag a member or else they won't get a notification you replied to them. If you ever need help with a build, read the following before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/Also, make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
