Best SFX PSU for SilverStone ML03b case
Go to solution Solved by W-L,
Hi everyone!
I have a SilverStone ML03b case with a A10-6800K and a low profile HD7750 and I'm currently looking to change my ATX Corsair PSU with something smaller . Preferably a SFX PSU since the space in this case is so limited :o
Do you have a good suggestion for me ?
Thanks a lot !
I believe Silverstone is the only one that makes SFX PSU's really, there are some small lesser know brands which I would probably stay away from but for that system, something like the 450W is more than enough with spare.
http://www.silverstonetek.com/product.php?pid=342&area=en
Hi everyone!
Thanks a lot !
Hi everyone!
Thanks a lot !
Thanks everyone !
I think it's really clear . I'm going to buy the PSU W-L suggested .
Thanks again1
