Silent PSU fan recomendation!
TJarsun
Hello! I'm on the search for a quiet 120mm fan for my PSU (Coolermaster expreme power plus 600w) because it runs at 100% all the time and its the loudest thing in my pc... I have other 7 fans + the included in the gpu + the cpu pump and they go really quiet, can almost never hear them but the psu is annoying!!!
Bear in mind I live on Argentina so I couldn't find any Noctua :( but I can find most cooler master, corsair, antec, nxzt fans!
Should I go for a airflow model or a static pressure one?
LianLi A71F Fulltower - i7 3770k delided + Corsair H60 - G.Skill Ripjaws 16 Gb @2133 Mhz - Sabertooth Z77 - Asrock Vega 56 - Asus Xonar Essence STX - Creative SoundBlaster Omni - 2x Corsair Force GT 120 Gb - 2x WD Green 2 Tb - 1x WD Blue 2 Tb - Corsair K70 w/ Red switches - Logitech MX Anywhere 2.
Corsair RM series is quiet in my opinion.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
Can you link us to where you're shopping/located?
I use the local ebay equivalent site and some local shops
Here are a few...
www.mercadolibre.com.ar
www.tricubo.com.ar
www.gameron.com.ar
I want to change just the fan, not the entire PSU!
I would have suggested Bitfenix Spectre Pros but for some reason only LED editions are available. Same thing with Aerocool stuff. NZXTs aftermarket stuff isn't that bad either
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Here are a few...
www.tricubo.com.ar
www.gameron.com.ar
TrueQuiet: http://articulo.mercadolibre.com.ar/MLA-552371131-cooler-pc-gabinete-antec-truequiet-120mm-led-fan-1000-rpm-_JM
