Wait for the 980ti / 390X.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4460942
970 sli will be fine.
290x crossfire is much better for 4k.
This is known fact .
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4460948
Don't get GTX 970 SLI, vram would be an issue AND 290/290X performs better in general
Get R9 290/290X Crossfire. Performs the same for wayyy less
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4460952
I said it would be fine, not great.
\/Specs\/
Xeon E3 1230 V3-Maximus vi hero-2x4gb G skill RipjawsX 2133-EVGA supernova-1 tb seagate-Samsung 840 EVO 1TB-NZXT H440-EVGA 6Gb 780 Razer-Blackwidow Ultimate-Corsair M65
MSI Ghost Pro GS60
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4460964
Ignore Zappian. She trolls every incarnation of this thread that appears.
970 SLI and 980 SLI perform similarly. Obviously 980 is slightly better, but it's also a lot more expensive. 290X Crossfire is also very good for this. It performs on par with the 970 SLI, with the actual victor being very dependant on the specific games you're playing and generally the difference in performance between the two is only a few FPS anyway. My advice would be to go with whichever is cheapest for you out of 970 SLI and 290X crossfire.
Don't bother with 8GB vram. It's unnecessary, and by the time you actually need that much vram you won't be happy with either 290Xs or a 970s at any rate.
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4460973
Personally I think an R9 295x2 is currently bar none the best solution for high end 4k gaming. It hits the exact comfort zone between cost, performance, convenience and silence. That said 2 970s are also a good option and if you want to spare some money, 2 290Xs will be just as great in terms of performance (albeit at the cost of noise and heat). I would stay away from: 980s (overpriced), 8gb 290Xs (overpriced and don't provide tangible benefits yet), 3-way whatever (more hassles than gains).
sudo chmod -R 000 /*
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4461013
Trolling = Knowing how to read graphs that show that amd cards works better at high resolutions.
I see.
Like @Sauron mentioned the 295x2 is the best solution for 4k gaming right now provided you have a decent psu.
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4461038
For AAA titles, two 290(x)'s/295x2 would be a good choice (could go 970's if you want, but for 4k 290(x)'s are generally a better value). If you don't play very demanding games you can easily get away with a single 970/290(x).
RIP in pepperonis m8s
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4461055
290X CF beats 970 SLI.... what are you on about
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4461059
The 290x CF/ 295x2 would be better but since the 390x is "rumored" to come with 8GB HBM, I'd wait for those to come.
If rumors are correct, 290x x2/295x2 will perform quite a bit better than a 390x for cheaper (there's no way in hell the 390x is going to be less than $600), and I doubt a single 390x is going to be able to drive modern AAA titles at ultra settings 4k 60fps. I think the 390x will only be worth it for crossfire setups (since two will likely be able to max out AAA titles at 4k, and currently you need 3-4 cards for that), but we'll see :)
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4461117
Yea but HBM though  ;)
And since we're talking about 4K, might as well go all out
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4461268
Titan Z?!
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4461279
I see.
Trolling = ignoring months of evidence from various benchmarks that contradict your misconceptions and obstinately parroting the same AMD-biased fan-rubbish.
Like I said the R9 295x2 does marginally better in some specific circumstances, and the 970s to better in some other specific circumstances, and either way the difference is slight. Get whatever is cheaper, or whichever your psu can handle.
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4461579
Because this question is asked so often, I made a chart comparing relative performance of more recent flagship graphic cards compared to the GTX 980. As you can see, the 295x2 makes a very strong case for 4K when you take into account multi-GPU scaling, at least until R9 390x and the GM200 flagship launch. clearly frame buffer is is important too.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4461646
They wont be here till July
Core I7 5960X / Gigabyte X99 SOC Force / Kingston 16GB DDR4 3000 / EVGA GTX 980 Classified's In Quad SLI / EVGA 1600W G2
Core I7 6700K / Asus Z170 Maximus VIII Hero / Corsair 16GB DDR4 3000 / MSI R9 290X Lightning / EVGA 1600W T2
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4461659
Ignoring evidence okay.
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4461662
Imagine though: if AMD can stroll in and slap a 400$ price tag on the 390x the 980 and 970 get thrown right out of the market unless they slice prices like there's no tomorrow. It would be a smart move by AMD and they have shown that they're willing to sacrifice margins to make sure their cards remain great value for the money. It my be their opportunity to flip the table and get closer to having 50% or more of the marketshare.
https://linustechtips.com/topic/328637-graphics-card-for-4k/#findComment-4461680
