When to water cool?
Solved by Pomfinator,
Water cooling is a "because I can" type of thing. Pretty much any system is absolutely fine running crazy overclocks on air, since OCing is not just dependent on temperature but stability of the voltage as well.
It's also far harder to maintain, takes a long time to set-up, costs significantly more money, and has a very high probability of messing up.
