Im trying to find the best mid range card. I have ben researching a LOT and found out that there are two cards in the similar price range and performance. Anyways whitch card do you recomend for under 300$ and witch of these two is better:
-Gigabyte GTX 960 G1   (2GB)
-Gigabyte Radeon R9 280X OC   (3GB)
What do you recomend? Sould I buy one of these two or wait for some TI`s or the R9 300 series but the 300 series are probably gonna be the new flagships.
https://linustechtips.com/topic/319752-help-me-find-the-right-gpu/
Hey there, welcome to the forums!
Out of those two the 280x is the winner, in my eyes.
If you feel like waiting, you could pick up the likes of a 290 or 970 if the price drop when the 300 series cards are released. Thats a big if though.
Bleigh!  Ever hear of AC series?
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
For under 300$ you can get an r9 290 and 290x. Both of these cards perform about 40-50% faster than either the 960 or 280x.
r9 290: http://pcpartpicker.com/part/xfx-video-card-r9290aedfd
r9 290x : http://pcpartpicker.com/part/powercolor-video-card-axr9290x4gbd5ppdhe
For $300? Neither.
Quite helpful that is. ;) JK
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
You are right, the only new GPU to be released in the 300 series are the flagship cards while anything below are rebrands. So you should just buy now.
From the two, 280X. They both perform pretty much the same while the 280X has 1 extra GB of vram so why not.
Although for $300, I'd rather a R9 290.
Of those two options, I'd pick the 280x. Going with a card under your budget though, you could potentially get yourself a 290x. I know MSi had their cards for $280 after MiR, and $330 before. Perhaps we'll see that again soon and you could snag one?
So, now you can crossfire these for less than the price of a 980!
As lots of others are saying you should probably get the 290, using one of the links that are being posted.
My PC Specs
CPU ¦ Intel Core i5 4690k @4.3GHz, Motherboard ¦ ASUS MAXIMUS RANGER VII, RAM ¦ 8GB (2x4GB) Corsair Value DDR3, Case ¦ Corsair SPEC-02, PSU ¦ Corsair CX600, Storage ¦ Samsung 850 EVO SSD 250GB, Seagate Barracuda 500GB 7200RPM, Seagate Barracuda 2TB 7200RPM, Western Digital Caviar Green 1TB 7200RPM, Mouse ¦ Corsair Sabre RGB Optical Gaming Mouse, Keyboard ¦ Cooler Master Quick Fire TK Cherry MX Blue, Headset ¦ Astro A40 2014 with Mixamp Pro, Microphone ¦ Blue Snowball iCE.
280x is a lot better
Not a lot better, but it can reach higher frame rates than the 960.
After I looked at a few benchmarks I would say the 280X has around 5-10% more power, but of course it'll probably also be a bit hotter and louder.
Between the 2 you posted - R9 280X is the best choice. No reason to pick GTX 960 unless you have size-thermal constraints, or really need one of the nVidia specific features, like G-Sync.
I would recommed R9 290 though - great card. The only problem is that you need a really good case with really good airflow and cable management, and good and reliable PSU that can deliver 40A on 12v rail(s).
not that much power geez I have my 290x on a 20a rail
There are three reasons to buy the 960 over the 280X:
1. You like Nvidia better (drivers/fanboi/shield streaming/etc)
2. You're limited by your existing PSU
3. You own a G-Sync monitor or intend to in the next 12-24 months.
Otherwise the 280X is the better choice IMO.
40A for all system. Also, 290X can draw more at times. Your rail is likely works above its rated load in games. Which is not unheard of, most good PSU can deliver at least 10-20% above their rated output without any issues whatsoever.
I have one of the lowest end PSU's there are..
THX for all of the advice im really grateful. But I do live in central europe and ALL of those links are ussless to me. Even do I would love to have a 290 or 290X They cost almos 500EUR witch is more than 550$ .The 280X costs almost 300EUR witch is like 340$. And I will still wait for the price to maybe go down a little bit. I am also confused why prices in europe are higher for all computer parts than in othe parts of the world. 1EUR is like 1.1$ so all of the parts sould be A LOT cheaper and they are saidly not.
