MOD04 - PARVUM VEER 1.0
MODZERO
Hey Guys,
I've been a huge fan of the youtube channel(s) for some time now. Decided to finally join the forums and share with you guys my latest build. I'm soon to start a new project and will start a 'Build Log' here when that kicks off. For now, though complete (just) I thought you may enjoy this. Looking forward to being apart of this community and contributing where I can.
So, MOD04. Parvum Systems are a UK based case manufacture (I'm sure you'll have other Parvum build threads here) I first saw at the number one UK LAN party called the iSeries. I'd wanted one ever since and finally got the opportunity to build in a 'then' unreleased case (They have launched this case in North America now as the Parvum Veer 1.0).
I created build logs over at OCN, OCUK and Bit-Tech and turned it around in just a couple months. It's been built as my LAN rig, as up until then I'd had taken my FT03 (watercooled), which was heavy and awkward to carry. Since completing this build I'd decided to transplant the hardware from my FT03 into a new case, of which will be the basis of my up coming build log.
SPECS:
Intel Core i7-4790K
Asus Maximus VII Impact Intel Z97
Kingston HyperX 8GB (2x4GB) 2400MHz
Inno3D GeForce GTX 980
Kingston HyperX 3K SSD 240GB
Corsair RM Series RM 650
PARTS:
EK - CoolStream PE 120
EK - CoolStream PE 240
EK FB Asus M6I - Nickel Plexi
EK - FC980 GTX Nickel Plexi
EK - FC980 GTX Backplate Nickel
EK - DDC Heatsink Housing Nickel
BP - Dual / Single DDC Top Upgrade Kit 80 (Clear Acrylic Cap)
BP - DDC TOP Acrylic
BP - Water Tank Z-CAP II - Three Port End Cap Plexi
BP - G1/4" Silver Shining Anti-Cyclone Adapter
3x Parvum Systems F1.0 500-1500 PWM 120mm Fans
Be Quiet! Silent Wings 2 80mm PWM
Laing DDC Pump 12v DDC-1T Plus PWM
FITTINGS:
8 x Bitspower Silver Shining Enhance Rotary 90-Degree Multi-Link Adapter (BP-E90RML)
13 x Bitspower Silver Shining Enhance 90-Degree Dual Multi-Link Adapter (BP-E90DML)
2 x Bitspower G 1/4 Enhanced Multi-Link Adapter - 12mm OD (BP-EML)
4 x Bitspower Silver Stop Plug - Screw Fitting (BP-WTP-C06)
1 x Bitspower Clear Stop Plug Fitting - G1/4" with 5mm LED hole (BP-ACSTI-BK)
1 x Bitspower Stop Plug Fitting - G1/4" Silver Shining w/ Slot (BP-WTP-C09)
1 x Bitspower Rotary Fitting "T" - 180 Degree - shiny silver (BP-TR-C)
1 x Bitspower G1/4" Silver Shining Anti-Cyclone Adapter (BP-WTP-C46)
1 x Bitspower G1/4" Silver Shining Aqua-Pipe I Fitting (BP-WTP-C17)
Hope you like the photos.
J.
- AKA HACKJOE -
Wow that is pretty build! love the case. Nicely done!
Welcome to the forums! :)
Bleigh!  Ever hear of AC series?
Very nice build, Must get people gathering around at LANs. How heavy is this to carry around with you?
That looks awesome nice work and welcome to the forums :)
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
Thanks and Thanks. Glad to be here.. hehe :)
I took it to the last iseries event which was winter lan, only a couple thousand gamers at that one, folk seemed to like it. Its fairly heavy but it's a simple box shape and very solid so it's much easier to transport then the FT03. Parvum are set to release some flight cases for their case range.. so that'll be awesome!
J.
- AKA HACKJOE -
Cheers.
gives @Jameswalt1 a run for his money :D
Haha, James Walts work is art! Huge fan of his builds, he was very helpful in my making of this one. Helped me out alot with the photography. Cant wait to see his EK Vulture build complete.
J.
- AKA HACKJOE -
  • 4 weeks later...
MOD05, my next project is nearing the end of it's planning phase, looking forward to kicking off the build log here soon.
J.
- AKA HACKJOE -
  • 1 month later...
cool tiny water cooled beast
Thanks, It was alot of fun building it. New project is getting closer.. I have a Parvum Trilogy planned, the sequel is shaping up nice. Logs to kick off soon.
J.
- AKA HACKJOE -
