Hi,  :)
I was wanting to know if there was any point to upgrading my mic setup.
Right now all I am using is a Blue Snowball (it was cheap).
I want my voice to sound great but is it even worth upgrading?
Most what I use my Mic for is constant skype calls, TeamSpeak, and Talking in video games.
Will those programs degrade the quality so much that it’s not worth an upgrade?
(I do make some videos and stream rarely)
Thanks in advance for anyone who can help me!  :D
https://linustechtips.com/topic/313603-wanting-some-help/
Yes, they do.
https://linustechtips.com/topic/313603-wanting-some-help/#findComment-4262957
Hi,  :)
What's wrong with the snowbal!?
I have a snowball and it's great :D
My friend has a yeti and for general gaming and recording use you can't tell the difference
https://linustechtips.com/topic/313603-wanting-some-help/#findComment-4262970
-snip-
Not worth the upgrade at the moment IMO.
You're not doing any recording so yeah.
The Snowball is still just fine for that.
https://linustechtips.com/topic/313603-wanting-some-help/#findComment-4262980
