Can any one help me with my ram problem?
Solved by Jumper118,
hi
these are to puush link to my pc specks and the problem :
http://puu.sh/fWOmT/aff3218422.png
http://puu.sh/fWSbt/382c4603ed.png
My motherboard is a MIS gaming 970
me and my fiends compared benchmarks on novabeanch because they was saying there CPU was better than my but that's a story for another day, anyway i found out my ram speed was about half of there's. As you can see it is 7057 MB/s but both of my frends are about 12771MB/s my ram is
Vengeance® — 8GB Dual Channel DDR3 Memory Kit
http://www.corsair.com/en-gb/vengeance-8gb-dual-channel-ddr3-memory-kit-cmz8gx3m2a1600c9
and its running at 1600mhz
Any help would be great
thanks
have you got it in the correct slots? it should say in the motherboard manual which 2 slots to use first.
