750D + Water (Warning, big picture heavy)
Jarand
So I’ve had my 750D for a while and been slowly upgrading, since I picked up a cheap 4820k I decided to do an overhaul.
New specs:
·         Basics
·         Intel 4820k
·         Asus X79 Deluxe
·         Corsair Dominator Platinum 2133 2x8GB w/light bar (will upgrade to 4x8 later)
·         2x Asus 980 Strix
·         Asus Xonar Essence STX
·         Corsair HX750 Silver
·         Corsair Black Sleeved Cable Kit
·         Icemods RGB LED Strip (1m)
·         3x Noctua NF-F12 Industrial PPC IP67 2000RPM
·         2x Noctua NF-A14 Industrial PPC IP67 2000RPM
·         2x Intel 730 240GB (Raid 0, Boot)
·         Samsung 850 Evo 500GB (Games)
·         Water Cooling
·         2x EK D5 pump
·         EX Dual pump top
·         2x EK Strix Acetal GPU Block
·         2x EK Strix Backplate Black
·         EK Supremacy Acetal CPU Block
·         360mm Black Ice GTSs Stealth Radiator
·         280mm Black Ice GTX Extreme Radiator
·         Bitspower 250mm WaterTank Z-Multi
·         Primochill LRT ½ ¾ Tubing
·         Various Bitspower matte compression/rotary fittings (90’, 45’)
·         Bitspower SLI Fitting
·         Desk Stuff (Bonus)
·         Ducky Shine 3 w/Keycool PBT keycaps
·         Logitech G502
·         ROG Swift
·         2x QNIX QX2710 debezelled
·         LG 25UM65 (1440x1080 IPS)
·         Corsair SP-2500
·         Audio-Technica ATH-AG1
·         Wireless Xbox 360 controller
·         OIfficeworks Apex 1800 Desk
So I wanted to clean up my tubing as it was all over the place and get a bigger res, without the stream crossing, also didn’t like the big curve between the radiators. I felt more confortable having 2 pumps on 3/5, hoping for a quiet build once the fans are tuned.
Without further ado;
Previous setup
Old mobo out
So many fittings (too many as it turned out
Glorious fans
Old mobo
New mobo
SSD mounting – must go for now
Old fans
Hopeful run after some modification
Out with the old
So much water cooling on the sink
And computer on the bench
Rads need some cleaning
Attempted marking
Bare metal case
Drilling – starting small, ended up 1 and ¼’
In with the new
Fits okay
Collatoral damage
Prepped new mobo
Fits nicely
Tubing begun
More progress
Tubing complete
Cable management needs improvement
Attempted to tidy, but complete
Panel back on
Lights on
Bonus desk shot
Thanks All
Great job! :)
Tubing runs are extremely clean; but what impresses me more is the rear.  Really, really orderly considering you have 3 SSDs and all of that hardware inside.
Also.. the setup is ridiculously nice.
Great work!
Thanks all
Great job! :)
PS Your build is really nice. Do you know hoow it looks in coloured lights? I'm considering putting EK pastel white fluid in my build, but I'm not sure if I could still 'change the colour of it'
Thanks. No, I removed the RGB lighting I had before I switched cases.
The nice thing about white though, is that you can change the colour scheme of your build by just changing the lighting :)
That's what I was hoping.
I think if I put white fluid in my system it could still look blue/red/green when I change the lighting (I have a remote from the icemodz kit I got)
