Difference in ASUS VX279Q and MX279H?
Solved by Sauron,
The panel is identical, however the MX one has better speakers, trace-free technology (less blurring in moving images, might work against you if you have an xbone though as the very low framerates will be more noticeable), draws less power and is a bit heavier. I can't help but wonder, why didn't you use the money for the xbone plus this to get a good pc instead? It would have made a lot more sense...
solaaaaa ·
Posted in Troubleshooting0 -
TantalizedMoon ·
wasab ·
Posted in Forum Suggestions4 -
8
6
