50$ Microphone for PC (US)
Go to solution Solved by RevoltTrain,
Blue Snowball is really solid. I used one for a couple of years
I need a microphone for around 50 dollars for thinks like skype and streaming. Audio quality isn't my number 1 priority but its definitely close. My top priority is that it dosnt make any annoying sounds like a ringing or static because thats the problem of my old one. I was thinking of getting the Blue snowball ICE but if there is something better i would like to know. (i have windows 7)
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/291548-50-microphone-for-pc-us/
ModMic, so it doesn't pic up typing and all the things that a desktop mic can.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/291548-50-microphone-for-pc-us/#findComment-3959441
Yeah, Modmic is pretty good, but the Snowball is awesome too if you have a place to put it.
It might pick up some typing
@Mohenjo don't forget to follow your topics
https://linustechtips.com/topic/291548-50-microphone-for-pc-us/#findComment-3959462
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/291548-50-microphone-for-pc-us/#findComment-3959464
snowballs pick up ambient sound very easily however quality is amazing
mod mic will do better at isolating your voice, but wont sound as good - more versatile maybe
https://linustechtips.com/topic/291548-50-microphone-for-pc-us/#findComment-3959472
im okay with my keyboard being picked up thats no problem i just dont want annoying sounds of static and an ear piercing noise my mic made for some reason
https://linustechtips.com/topic/291548-50-microphone-for-pc-us/#findComment-3959489
 it wont do that
also the AT2020 is a good mic too not sure if its in budget :D or some of the samson ones :D
https://linustechtips.com/topic/291548-50-microphone-for-pc-us/#findComment-3959496
Parents only let me buy from trusted online websites like amazon and newegg. And trust me there dense soo yea...
https://linustechtips.com/topic/291548-50-microphone-for-pc-us/#findComment-3959499
Thanks for the help but i guess ill stick to the snowball. My local tech store has and that relives the pain of waiting and not being able to skype :D
https://linustechtips.com/topic/291548-50-microphone-for-pc-us/#findComment-3959520
