Help identifiying screws in computer
Sdot
I have a Razer Blade 17"
I don't necessarily understand why it's just falling apart like this but do any of you know which screws I need to order to try to put this back together?
Here are some pictures.
http://imgur.com/a/NlA7q
Also, if I buy new screws will they even hold? I don't understand how screws just fall out.
probably not, im guessing the hole is stripped
use glue to hold it together because another screw would either fall out because it is the same size or damage the notebook because it is too big
:( that's what I figured
Idk how it got stripped, thought I took really good care of this and now screws are falling out for no reason. wtf??
Razer quality.  B)
lol.. I feel sory for you man Q.Q .. so much for razer build quality... -.- , not sure how to fix that... glue probably wont help much... maybe some tape around the corner... xD
Razer quality.  B)
I have 2 naga mice, 2 blackwidows, 1 Tiamat, etc. and all that stuff has been fine for years.
Is the screw still in there?
yeh you guys are right, screws prob won't work and I don't wanna glue or tape this up. damn, idk
If you have a local PC store which knows just a little about PC hardware they might have a couple of matching screws.
You could always give it a shot, at least it's going to keep your PC together for a little longer :)
When in doubt: C4
Probably screwed into plastic, over tightening or too much pressure pulling on the screw can easily strip the hole.
it wasnt you, it must have just been defective...:(
I understand that nothing lasts forever but it just sucks to see this fall apart like this. Maybe I'll see what razer support suggests I do.
Sorry, but I couldn't resist.
polls_3705196162_a6a8b2c771_5333_497431_
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
