Do i need a 64 bit cpu for a 64bit os?
Yes.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/279285-64-bit-cpu/#findComment-3790528
@Belo1301 welcome to the forum. remember to read the COC and like and select best answer for you questions! enjoy your stay.
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/279285-64-bit-cpu/#findComment-3790545
Yep, it will refuse to even install on a 32-bit microprocessor. Tho 32-bit versions of OS's will run on a 64-bit CPU.
How do i know that hte cpu  I buy is 64 bit?
Sory for the stuped question im new to this :)
All modern desktop microprocessors are 64-bit capable.
https://linustechtips.com/topic/279285-64-bit-cpu/#findComment-3790560
Yes, you would have to go back to before the Athlon 64 (2003) before you would find a 32-bit native architecture.
Or a smartphone
[spoiler=My PC]
CPU: Intel Core i7 6700K | COOLER: Corsair H105 | MOBO: ASUS Z170i Gaming Pro AC | RAM: Corsair LPX DDR4 16GB 2400MHz | GPU: EVGA GTX 980 Classified | CASE: BitFenix Prodigy | SSD: Samsung 950 Pro 512GB | PSU: XFX XTR 650W [spoiler= Le Other Stuff] Monitor: BenQ XL2411Z | Keyboard: Ozone Strike Pro | Mouse: A4 Tech X7 F4 | MousePad: Ozone
PlayStation 2 | PSP 2000 | Game Boy Color | Nintendo DS Lite | Nintendo 3DS | Wii
Sony Xperia J (Why u so bad D:) | iPod 4th gen | iPhone 4 | Yarvik Xenta 13c (3muchchrome5her)
Pentium B980 | 500GB WD Blue | Intel HD Graphixxx | 4Gegabeytes of REHAM
Current OS: MSX 10.0 ( ͡° ͜ʖ ͡°)Ilikethelennyfaceyouknow( ͡° ͜ʖ ͡°) Windows Password Reset Guide
https://linustechtips.com/topic/279285-64-bit-cpu/#findComment-3790644
Actually, just get a 2006 laptop with the centrino duo platform and you can find 32bit only support (Toshiba Tecra M5 is a good example).
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/279285-64-bit-cpu/#findComment-3790736
True xD. Even my old X2 7750 was 64bit although it came with 32bit win vista ...
My Rig: AMD Ryzen 5800x3D | Scythe Fuma 2 | RX6600XT Red Devil | B550M Steel Legend | Fury Renegade 32GB 3600MTs | 980 Pro Gen4 - RAID0 - Kingston A400 480GB x2 RAID1 - Seagate Barracuda 1TB x2 | Fractal Design Integra M 650W | InWin 103 | Mic. - SM57 | Headphones - Sony MDR-1A | Keyboard - Roccat Vulcan 100 AIMO | Mouse - Steelseries Rival 310 | Monitor - Dell S3422DWG
https://linustechtips.com/topic/279285-64-bit-cpu/#findComment-3791131
I havent heard someone ask about 32 and 64 bit cpus since 2008... (are 32 bit ones even manufactured anymore??)
Yes that cpu is 64 bit.
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/279285-64-bit-cpu/#findComment-3792929
