Audio Technica ATH- M40x vs Sennheiser hd 280 pro
Solved by ShearMe,
Ya i saw that video, but for me the sound isolation and comfort perhaps is even more important than sound. I current have the UE 6000, and the sound isolation is really iffy on it.
I don't think anything under $100 is going to be all that much better than the UE6000, which is a pretty good closed can in it's own right.
Tyll from Innerfidelity graphs all the headphones mentioned so far, including isolation performance. UE6000, M50X (isolation should be about the same as the M40X), HD 280 Pro, and MDR-V6 (again, isolation should be about the same as the 7506).
