No the processor is not bottlenecking the GPU, I had a superclocked 780 ti and I struggle to get 40 - 45 FPS in ARMA 3. This game performs differently on every rig .. dont know why
"If Everton were playing at the bottom of the garden, I'd pull the curtains." - Bill Shankly
That is a a very balanced system, so no need to worry about bottlenecking.
I can attest to DayZ running like utter crap as well.
DayZ is not a game where you should test your PC. It's not even on Beta, and graphics are just retardedly demanding for no reason.
Rig: I5-3570K@4.3Ghz - Cooler Thermaltake Frio Advanced - Ram Kingston 1333Mhz 8gb (2x4) - GPU GTX 970 4GD5T OC - Motherboard Z77MA-G45 - PSU CoolerMaster GX II 750w - Storage WD 500gb HDD - Sound Edifier M3700 5.1 - Headset Corsair Vengeance 1500 - Mouse Razer Deathadder 2013 - Keyboard Razer Anansi - Mousepad Steelseries QcK+ - Xbox 360 Wireless Controller x2
i5 4690k
Get rid of that quad core, get like an 8350 or something.
Nice try, but that is not the culprit.
what could be happening then?
Well, DayZ is very very badly optimised. So, the wind is probably blowing in the right direction.
Make sure her settings are fine on the game. Arma has some super intensive settings that can be enabled....
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
May not be, but going from 4 cores at 3.5 Ghz to 8 at 4Ghz is a good upgrade.
More cores =/= better when comparing AMD to Intel. AMD may have 8 cores, but Intel's are faster.
And the speed increase? Your logic is lacking.
Again, It doesn't work that easy.
What.....
http://linustechtips.com/main/topic/111882-the-4670k-or-3570k-vs-8350-aggregate-comparison/
Just read this and stop talking.....
I don't think you know how anything in a computer works looking at your posts cokeman.
Agreed
Very condescending for someone who doesn't know basic knowledge.
Its a review quoting multiple reviews that prove through benchmarks that the 8350 is no better than an old 3570k in the majority of cases.
Have fun educating yourself with facts:
Bench 1:
http://www.bit-tech.net/hardware/2012/11/06/amd-fx-8350-review/6
Bench 2:
http://www.tomshardware.com/reviews/fx-8350-vishera-review,3328-13.html
Bench 3:
http://anandtech.com/bench/product/697?vs=701
Bench 4:
http://www.techpowerup.com/reviews/AMD/FX-8350_Piledriver_Review/5.html
Bench 5:
http://www.extremete...er-fell-short/2
Bench 6:
http://www.legitrevi...-review_2055/15
Just like your posts :)
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
