Get the 280...  Moar VRAM means you can run at higher settings...
https://linustechtips.com/topic/252951-please-help/#findComment-3465580
Low clock speed is no issue ?
Low WHAT speed? :D
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/252951-please-help/#findComment-3465591
Low cock speed is no issue ?
Lower clock speed but better chip with more stream processors.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/252951-please-help/#findComment-3465598
I think it's a no-brainer. AMD R9 280 FTW! :D
https://linustechtips.com/topic/252951-please-help/#findComment-3465601
That's what overclocking is for... Sapphire has pretty good chips (from experience) and their cooling solution is also good, so there should be few problems (as long as your PSU can handle it)...
https://linustechtips.com/topic/252951-please-help/#findComment-3465612
850 Mhz v 1100 Mhz ?
You left the "L" out of "clock". :D
https://linustechtips.com/topic/252951-please-help/#findComment-3465636
Get the 280.
https://linustechtips.com/topic/252951-please-help/#findComment-3465655
Low  "cock" speed hahahahahahaha
Yes, I too had a bit of a chuckle. :P :lol: LOL
I see that you've fixed it now. I edited your post upon quoting it and included the
missed out letter. Unfortunately some have not edited there quote of yours. :D
https://linustechtips.com/topic/252951-please-help/#findComment-3465687
Also guys, while I was looking I found Vapor X 280X for 80$ more, but I have 650W PSU. Part picker says that it will all go well, but Sapphire official page says that 280X needs 750W to run. Has anybody got 280X and what PSU if so ?????
Here a 280x Vapor-X with XFX 650W and it's more than enough :)
https://linustechtips.com/topic/252951-please-help/#findComment-3465792
Now I really don't know what to do...If my PC blows up I will be out of money and out of PC lol. It says 750W minimun for 280X but you say and almost whole internet that it doesn't need more than 600W. Hard choice.
https://linustechtips.com/topic/252951-please-help/#findComment-3465883
I had those concerns before buying the gpu but after I bought the gpu and PSU I knew it was all in vain the PSU produce more that the required amps on the 12V+ rail just make sure that it have 2 6+2 pin connectors or 2 8 pins power connectors
They are saying 750W in the sapphire website because, some are gonna buy cheap PSU that deliver less wattage then it supposed to so sapphire said 750W ro avoid those
https://linustechtips.com/topic/252951-please-help/#findComment-3466116
Thanks Man !
https://linustechtips.com/topic/252951-please-help/#findComment-3466291
