My first PC Build!
Go to solution Solved by AlwaysFSX,
My budget is about 800 dollars. So would you recommend scrapping the APU and going with a different graphics card as well? Or should I stick with the APU and change the graphics card?
Here's my suggestion:
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($124.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($31.99 @ Amazon)
Motherboard: Gigabyte GA-78LMT-USB3 Micro ATX AM3+ Motherboard  ($54.98 @ NCIX US)
Memory: Team Zeus Red 8GB (2 x 4GB) DDR3-1600 Memory  ($64.99 @ Newegg)
Storage: Sandisk Ultra Plus 128GB 2.5" Solid State Drive  ($66.50 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($51.99 @ Directron)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card  ($252.00 @ Newegg)
Case: Aerocool DS Cube Black Edition Silent Cube MicroATX Mini Tower Case  ($98.99 @ Directron)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($54.99 @ Amazon)
Total: $801.42
Generated by PCPartPicker 2014-11-17 18:27 EST-0500
Ok so this is my frist PC build ever, but I'm a little confused. So I put together this first build and it looks like this:
CPU: AMD A10 7850K Quad Core APU
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+
Memory: G. Skill Ares Series 8GB (2x4GB) DDR3-2400
Storage: Western Digital Caviar Blue 1TB 3.5'' 7200RPM Internal Hard
Video Card: MSI Radeon R7 260X 2GB Video Card
Case: Aerocool DS cube Black Edition Silent cube
Power Supply: SeaSonic 400W 80+ Bronze Certified ATX Power
I'm not a huge PC gamer, I prefer consoles, but there are a few PC games that I would like to play, like Assetto Corsa maybe. I thought that this would provide me with a value gaming solution as it would allow me to crossfire the r7 260x with the on board graphics.
But then I started looking around and I saw an AMD FX8320 which has 8 cores and runs at 3.5 GHz and is a little cheaper than the A10. But then I would have to get a better graphics card, and change the whole build really, and I would lose the value that the original build had.
Can I get some suggestions from you guys on what I should do? I'm really leaning toward A10 because of its value and the fact that it will get better over time as game developers start optimizing their games for Mantle.
https://linustechtips.com/topic/252617-my-first-pc-build/
Nice ! Good job for a first time man happy gaming if you want tips i would personally stick with the apu and maby get this gpu http://www.amazon.com/XFX-Double-933MHz-Graphics-R9280ATDFD/dp/B00J44WVYG/ref=sr_1_2?s=pc&ie=UTF8&qid=1416264397&sr=1-2&keywords=r9+280
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461159
Swap the 7850k for a 760k/860k and swap the 260x for a 270.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461173
don't get an APU, just get a normal processor and a better GPU like a 270x
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461194
He could get an APU but he might be better off going for an R7 250(x) so that he could access the integrated GPU and the dedicated GPU.
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461237
A dedicated gpu is ONLY good on a very tight budget (and by that I mean VERY tight).
a 760k + 270 ($200~) will beat a 7850k+250x ($240~)
PSU Tier List | CoC
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461247
APU -> No dedicated GPU
Dedicated GPU -> APU becomes useless
I would not buy that system. What's your budget for the system?
This.
Since you already have a GPU, you might as well get the better stand alone CPU, then spend the extra $30 into a better GPU.
Try to at least get a 280.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461288
OT, I changed the gif I used I had higher expectations.
Anyways, yeah I suppose.
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461296
yes, that is also a good idea and probably cheaper
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461297
Can we have a your budget and location?
You can do better.
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461509
My budget is about 800 dollars. So would you say get a different GPU or a better processor and a different GPU???
you could definitely get a much better PC for $800.
INTEL i7 4790K | GIGABYTE GA-Z97X GAMING 5 | A-DATA 16GB | PCS+ R9 290 | SAMSUNG 840 EVO | MOMENTUS XT BARRACUDA |  FRACTAL DESIGN R4
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461510
You're in luck because I just finished building a ~$850 build for somebody else.
If you're in the US...
I forgot to add a 1TB HDD. If this is out of range, take out the SSD and cut some corners.
PCPartPicker part list: http://pcpartpicker.com/p/DxRtrH
Price breakdown by merchant: http://pcpartpicker.com/p/DxRtrH/by_merchant/
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  ($116.94 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.98 @ OutletPC)
Motherboard: Gigabyte GA-H81-D3 ATX LGA1150 Motherboard  ($58.99 @ Directron)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($119.99 @ Amazon)
Video Card: PowerColor Radeon R9 290 4GB PCS+ Video Card  ($249.00 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($49.99 @ Amazon)
Power Supply: Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($69.99 @ Micro Center)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($13.99 @ Newegg)
Operating System: Microsoft Windows 8 (OEM) (64-bit)  ($97.46 @ OutletPC)
Wireless Network Adapter: Asus PCE-N10 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  ($14.36 @ SuperBiiz)
Total: $885.68
Generated by PCPartPicker 2014-11-17 18:21 EST-0500
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461531
Total: $801.42
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461563
Total: $801.42
Yeah i like this. Do you think it would game well? Sorry for that question, i'm still learning. haha
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461609
The R9 290 is the second fastest card AMD has out at the moment, yeah it can game pretty well. :lol:
hahaha alright man thanks so much!!! I really appreciate it. And you used some of the parts that I picked out so it still feels like my creation. haha
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461636
:D If you've got any more questions don't hesitate to ask us, we'll do our best to answer them.
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461641
Hey man, one more question. Do I have to get a wireless card or does the MOBO have on-board wireless capabilities?
You will need a wireless card. Which I think screws with the build because of the slots... I'll fiddle with it after taking a shower.
https://linustechtips.com/topic/252617-my-first-pc-build/#findComment-3461743
