 I wanted some good subwoofers for my PC, preferably BIG ones that get some serious thump.
I have a logitech z506 5.1 surround kit right now, but the sub is like 6 inches and while it's loud, I want it louder.
Can I use car subs? And if I can, how do I go about powering them+ wiring them up?
I want like 2 12's or 2 14/15's.
https://linustechtips.com/topic/25150-subwoofers/
i think you are going to be deaf if it's going to be louder than a logitech z506
Yolo sir. Yolo.
https://linustechtips.com/topic/25150-subwoofers/#findComment-318804
If you want big and loud, you could go with a Carwin-Vega http://www.cerwinvega.com/pro-audio/powered-speaker-system/active-subwoofer/cva-121.html
Where do I buy one, and how would I hook it up?
I don't know much about audio stuff besides headphones :s
https://linustechtips.com/topic/25150-subwoofers/#findComment-318815
the easiest setup would be to take a bazooka car sub and splitting one of the audio lines and feeding it to the sub which would take a 2 line input which is what you would get if you cut a 3.5mm lines from your computer
http://www.bazooka.com/
and to feed the sub's built in amp power feed it via old shitty PSU
http://www.instructables.com/id/Car-Amplifier-and-Subwoofer-Powered-By-a-Computer-/
I've ripped apart a PSU to power HID light bulbs for my halogen to HID conversion/retrofit on my car it is pretty easy to do. just be sure which line you use.
edit: you don't necessarily have to get the bazooka I just thought it was the most noob friendly. you can just go to a local pawn shop and pick up an amp/sub combo there take advantage of savings on the backs of people who don't know how to budget
https://linustechtips.com/topic/25150-subwoofers/#findComment-318841
I have a quick question about this.
What is a Subwoofer?
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/25150-subwoofers/#findComment-318870
A speaker, seperate from the main speaker cabnet, typically built with a separate amp that provides the lowest audible frequencies heard.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/25150-subwoofers/#findComment-320460
you can have more than one now too. Mostly for really big rooms and silly imgur jokes:
"Pardon my French but this is just about the most ignorant blanket statement I've ever read. And though this is the internet, I'm not even exaggerating."
https://linustechtips.com/topic/25150-subwoofers/#findComment-320679
I found the pic I took. the fan was there because I think you need a load to put on one of the lines or something. either way read the guides it is very easy to do, its been years since I did this so unable to provide further instruction
edit: before I get flamed for using electrical tape and the looks of it I only needed to power it up for a few minutes so I could adjust the shrouds with washers so that I could get the rainbow coloring effect to happen (refraction from the shroud)
https://linustechtips.com/topic/25150-subwoofers/#findComment-322910
