Is this Setup a good idea for GPU Water Cooling Build?
Solved by Aniallation,
no i dont have that luxury srry
If you can't bring ambient temp down then there won't be a big difference by using a water cooler since delta temps over ambient will be the same.
Featured Topics
AleksiDj73 ·
Posted in Peripherals0 -
Micro2000 ·
Posted in General Discussion4 -
djksm ·
Posted in Member Reviews2 -
DarthAegon ·
Zarous ·
Posted in Cases and Mods0 -
E4GLE.010 ·
Posted in General Discussion10 -
6
pjewett ·
Posted in New Builds and Planning4 -
Edward78 ·
Posted in Linux, macOS and Everything Not-Windows1
