How to find a balance between my speakers and subwoofer
Solved by Krishtrinity,
Start both from 0 volume.Increase the volume until you find correct balance.For most of the subwoofer ideal volume is set at the half the point anything over that will be boomy and overpower the speaker sound.Set an ideal volume for speakers and just use the pc volume from then on.
Featured Topics
svvkjbe ·
Posted in Graphics Cards1 -
TheDarkLoS ·
Posted in New Builds and Planning2 -
bensinspade ·
Posted in Graphics Cards5 -
CloseTheDoor ·
Posted in New Builds and Planning11 -
1
pchelp ·
Posted in CPUs, Motherboards, and Memory18 -
pontikos ·
Posted in Troubleshooting2 -
12
wolfgangam ·
Posted in Windows5
