Minesweeper.
https://linustechtips.com/topic/236645-need-help-with-4k/#findComment-3243916
Minecraft
https://linustechtips.com/topic/236645-need-help-with-4k/#findComment-3243923
Nice logo dude, try CS GO :P
PC : | CPU: Intel 4790K | COOLER: Corsair H105 w/ JetFlo's Push/Pull | MOBO: EVGA Z97 Classified | GPU: EVGA FTW 4GB GTX 970 X2 | RAM: Kingston HyperX Beast 1866Mhz 32GB | CASE: HAF Stacker 945 | PSU: Corsair AX1500i | DISPLAY: Asus MX299Q | SSD: 2 X Corsair Neutron GTX 480 GB in RAID0 | mSATA SSD: Samsung 840 EVO 500 GB | HDD: 4 X Western Digital RED 4 TB in JBOD |
https://linustechtips.com/topic/236645-need-help-with-4k/#findComment-3243925
not that many games...
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/236645-need-help-with-4k/#findComment-3243968
Wolfenstien 3D. It's on steam for $4.99
https://linustechtips.com/topic/236645-need-help-with-4k/#findComment-3243984
I saw some people doing titanfall on a 290, i figured i would try that when i got home.
Give it a go, and report back. I would bet you have to lower the settings a bit to get reasonable frame rates but if you do better let us know.
https://linustechtips.com/topic/236645-need-help-with-4k/#findComment-3244016
Only problem atm is my fx 6300 is gonna bottleneck me pretty bad. My mobo for my 5820k wont be in until thursday so im stuff with this thing for now
https://linustechtips.com/topic/236645-need-help-with-4k/#findComment-3244041
Not likely, especially at such a GPU-bound resolution, and with a game built on such an old engine.
https://linustechtips.com/topic/236645-need-help-with-4k/#findComment-3244054
so i tried it at 1440p, and my life is now changed forever. 1080p is not good enough. So i tried it again at 4K, and my whole computer restarted after about 10 seconds of being in game. Am scared to touch 4K now.
https://linustechtips.com/topic/236645-need-help-with-4k/#findComment-3246455
