WD green Problem
Solved by SuperSoph_WD,
Hey there, @Aussie Pawz!
As the community already mentioned, you need first to partition and format the HDD before you can actually use it.
I can suggest to take a look at these couple of guidelines that should help you out with that!
How to install a SATA HDD: http://products.wdc.com/library/um/eng/4779-705037.pdf
How to partition and format an HDD on Windows: http://wdc.custhelp.com/app/answers/detail/a_id/3865
I hope you find this helpful. Keep us posted if you need further assistance!
SuperSoph_WD
