I must apoligize for the poor picture quality as they were taken on an iPhone, The Red LED's have been washed out a bit due to the camera flash but i positioned the LED strips so it gives more of a glow than an overpowering glare but im tempted to switch to white LED's not sure what colour would you guys go for on this build? Anyway moving on the last thing to be done is upgrade from the current i5 4670K to the i7 4790K.
Specs:
Intel i5 4670K @ 4.0GHz (Upgrading to i7 4790K November 2014)
MSI Z87-G45 Gaming
Team Group Xtreem LV 16GB DDR3 2400MHz
2x Inno3D Geforce GTX 980
EVGA Supernova G2 750W
Western Digital Caviar Black 2TB
Kingston 120GB SSDNow V300 Drive 120GB
Corsair C70
Corsair H110
2x Noctua Industrial 140mm 2000rpm fans fitted to the Corsair H110
Front intake Corsair stock H110 140mm fan
Floor intake Corsair stock H110 140mm fan
Rear exhaust Corsair stock C70 120mm fan
HDD cage fans 2x Corsair stock C70 120mm fan
Bitfenix red LED strips
Mnpctech Corsair C70 clear window
10711131_4707806911063_55569657316629598
10703598_4707806951064_18491121992504609
10388570_4707802630956_41499297366480360
10698547_4707802910963_65189308989581319
10626533_4707802990965_84464098243831104
1606885_4707803910988_519528476362057824
10407819_4707804030991_37474846004953955
10626544_4707804230996_63859609960396221
1911734_4707804270997_199377358477914800
10696344_4707804511003_65184113174771831
https://linustechtips.com/topic/231559-project-maxwell/
I don't like the red light, maybe cuz is just a abit or idk, just doesn't fit for me, white would be more nice I belive.. But is a beast!! How much did it cost you?
The blood on to your heart start pumping faster when you notice me.
But is ok.
Judge me for my nickname, my avatar and for the low amounts of posts I have. I will keep your heart beat raised.
https://linustechtips.com/topic/231559-project-maxwell/#findComment-3166123
Yeah i had the red LED's left over from a previous build i think i will switch to white soon! Roughly £1800 if you count the i7 4790K when i upgrade next month and forget the i5 probs about £1950
https://linustechtips.com/topic/231559-project-maxwell/#findComment-3166143
Fancy seeing your build on this forum Axon. :D
●CPU: i7-4790K w/H100i ●Mobo: MSI Z97 MPower ●RAM: Corsair 16GB Dominator ●GPU: EVGA ACX SC 780 3GB(X2) ●SSD: 850 Pro 256GB ●Case: 450D ●PSU: AX 860i ●Monitor: Asus PB278Q 1440p
https://linustechtips.com/topic/231559-project-maxwell/#findComment-3170375
Scoring 5539 on Ugine Valley and 18990 on Fire Strike should be better once ive fitted the i7 :)
Normal Fire Strike or Fire Strike Extreme?
Quote
Ignis (Primary rig)
CPU
 i7-4770K                               Displays Dell U2312HM + 2x Asus VH236H
MB ASRock Z87M Extreme4      Keyboard Rosewill K85 RGB BR
RAM G.Skill Ripjaws X 16GB      Mouse Razer DeathAdder
GPU XFX RX 5700XT                    Headset V-Moda Crossfade LP2
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Storage PNY CS900 120GB (OS) + WD Blue 1TB
Quote
Server 01Alpha                                       Server 01Beta                            Chaos Box (Loaner Rig)                Router (pfSense)
CPU
 Xeon X5650                                      CPU 2x Xeon E5520                    CPU Xeon E3-1240V2                     CPU Xeon E3-1246V3
MB Asus P6T WS Pro                               MB EVGA SR-2                             MB ASRock H61MV-ITX                 MB ASRock H81 Pro BTC
RAM Kingston unbuffered ECC 24GB  RAM G.Skill Ripjaws 16GB         RAM Random Ebay RAM 12GB    RAM G.Skill Ripjaws 8GB
GPU XFX R5 220                                       GPU EVGA GTX 580 SC               GPU Gigabyte R9 295x2                GPU integrated
PSU Corsair CX430M                               PSU Corsair AX1200                   PSU Corsair GS700                         PSU Antec EA-380D
Case Norco RPC-450B 4U                      Case Rosewill  RSV-L4000C        Case Modified Bitfenix Prodigy   Case Norco RPC-250 2U
Cooling Noctua NH-U9S                        Cooling 2x CM Hyper 212 Evo  Cooling EVGA CLC 120mm           Cooling stock
Storage PNY CS900 120GB (OS)           Storage null                                 Storage PNY CS900 120GB (OS)  Storage Fujitsu 150GB HDD
               8x WD Red 1TB in Raid 6        WD Black 1TB
               WD Green 2TB
https://linustechtips.com/topic/231559-project-maxwell/#findComment-3173839
Eh? lol are you saying i post too much :P
Nah, just saying I like seeing your build on any forum lol  :D
https://linustechtips.com/topic/231559-project-maxwell/#findComment-3174091
Dude thats sick! That is almost exactly what i wanted to do with mine (if i got the money for the cards and psu)!
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/231559-project-maxwell/#findComment-3175656
  • 3 weeks later...
  • 2 weeks later...
