I had no idea where to post this
Why do my games look this bad compared to my PS2? Is there any settings I didn't change? Can I improve it?
I see that the top says 512x512, but surely this can't be the resolution, right?
PS2 resolution is 720x480, so it's likely scaled unproperly
"Rawr XD"
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3142987
Looks like a bad upscale...
Try setting the rendering (can't point it out right now since I'm not at my main rig) resolution to 720p, and the PS2's aspect ratio via the bios to 16:9...
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143007
Sorry for double
Surely it could look better than this
PS2 games compared to today's games obviously will look like crap lol
512x512 isn't the correct resolution though. It's supposed to be rectangular, not a square.
"Rawr XD"
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143011
I still own a PS2 though, and it looked much better, I'll just try playing around with the resolution and rendering as the others said.
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143031
If i remember currently,in the settings there is an option to keep the resolution as the original resolution
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143037
Me too
#PS2MasterRace
ExSystems
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143044
There is the 4:3 option which makes some games look better...
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143045
Me too
#PS2MasterRace
I can't believe I still see people with actual PS2s... Brings tears of joy to my eyes...
I've got the thick version... Still works perfectly... I'm enjoying some Gundam games on the platform...
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143054
Go to Config > Video (GS) > Plugin Settings
Then make sure you untick Original PS2 Resolution and use Scaling of 4x to 6x.
That should make things better.  FXAA and FX Shader aren't really necessary and cause extra load for minimal visual improvements.
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143062
I still have mine (slim one) and i had so many chances of selling it but i just wanted to keep it as a memory/collectable
I played more games on that then on Pc
ExSystems
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143074
gotta be a multiple of 720x480 (1.5x does count, just HAS to be from that res)
1080x720 would be 1.5x
1440x960 would be 2x
512x448
this is what it should look like at these settings on a 1440p desktop space
your settings should look like this, but I'm using a 770 at stock OC, so you can probably pick something a bit more aggressive.
config > Video GS > Plugin settings
Window settings drop down option under video GS shouldn't matter as long as you have wide screen ratio selected.
you can crank up MSAA in the "hardware hacks" section.
Error: 410
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143099
512x448
What Resolution do you have at Config -> Emulation settings -> GS window? and what aspect ratio there
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143287
Beach I've got three, and mah daddeh has two!
Do not  as I  do, and  not  as I say. Instead do as you may..
HSS Revenir: CPU=i7 5960x @4.5GHz Heatsink=Corsair H100i MOBO=ROG Rampage 5 RAM=Kingston HyperX Predator 16GB @3000MHz SSD=Corsair Neutron GTX 480GB GPU=R9 295x2 PSU=Corsair AX1500i OS=Windows 7 Ultimate
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143411
16:9 is all that matters
resolution is dynamic and changes when you resize the window or full screen it, so changing that option does literally nothing.
Error: 410
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143453
I thought so aswell. NFS 2 goes down to like 3 fps though when actually in-game. Tekken has this weird artifacting (The black lines)
http://i.imgur.com/NcN1ezV.png
Edit: Why the hell does NFS 2 use 3GB of vram
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143495
if you want your games to be rendered at 1080p, regardless of window size, follow @helping 's steps, but uncheck the native box in D3D internal resolution and enter 1920x1080 in the custom resolution box. Like this:
| My first build: http://linustechtips.com/main/topic/117400-my-very-first-build/ | Build for my friend's 18th: http://linustechtips.com/main/topic/168660-pc-for-my-friends-18th-with-pictures-complete/ |
ATH-M50X Review: http://linustechtips.com/main/topic/165934-review-audio-technica-ath-m50-x/ | Nintendo 3DS XL Review: http://linustechtips.com/main/topic/179711-nintendo-3ds-xl-review/ | Game Capture Guide: http://linustechtips.com/main/topic/186547-ultimate-guide-to-recording-your-gameplay/
Case: Corsair 200R CPU: i5 4670K @ 3.4GHz RAM: Corsair 8GB 1600MHz C9 Mobo: GIGABYTE Z87-HD3 GPU: MSI R9 290 Cooler: Hyper 212 EVO PSU: EVGA 750W Storage: 120GB SSD, 1TB HDD Display: Dell U2212HM OS: Windows 8
https://linustechtips.com/topic/229633-pcsx2-terrible-quality/#findComment-3143529
