Hello,
I am going to be watercooling 2 gtx 980s in sli on an asus maximus vii hero in the top 2 slots.  Could somebody link me to an appropriate sli bridge for my setup.  I am going to be using 1/2 3/4 inch tubing if that matters.  Also, how many compression fitting would i need for them with the sli bridge.  would it be one for intake then the sli bridge then one for out take on the second card, or would i need 4 for each intake and outtake.
Thanks
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/224938-water-cooling-sli/
Hello,
Thanks
and btw im using this water block http://www.frozencpu.com/products/25575/ex-blc-1845/EK_Geforce_GTX_980_VGA_Liquid_Cooling_Block_-_Nickel_Acetal_EK-FC980_GTX_-_AcetalNickel.html?tl=g30c311s2312#blank
https://linustechtips.com/topic/224938-water-cooling-sli/#findComment-3081355
You don't water cool an sli bridge...
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/224938-water-cooling-sli/#findComment-3081359
Hello,
Thanks
You can get a 3-slot dual GPU bridge from EK in either a serial or parallel config which only requires one fitting for the in and one fitting for the out.
These will work with the Hero VII but you can double-check the compatibility on the EK website.
Serial: http://www.frozencpu.com/products/16696/ex-blc-1185/EK_FC_Bridge_Dual_Serial_3-Slot_CSQ_-_SLI_Connection_-_Acetal_EK-FC_Bridge_DUAL_Serial_3-Slot_CSQ.html#blank
Parallel: http://www.frozencpu.com/products/16697/ex-blc-1186/EK_FC_Bridge_Dual_Parallel_3-Slot_CSQ_-_SLI_Connection_-_Acetal_EK-FC_Bridge_DUAL_Parallel_3-Slot_CSQ.html#blank'
Temp/performance difference between serial and parallel is negligible, get the one that makes the most sense in your head. Serial is recommended for 2 GPU's.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/224938-water-cooling-sli/#findComment-3081397
How would i install something like this, do i need any fitting or extra tubing for it or does it come with everything i need
https://linustechtips.com/topic/224938-water-cooling-sli/#findComment-3085524
You just need two compression or bard fitting with G1/4 threads. One for the in, one for the out. Every EK waterblock comes with the bridge link you need for it to attach to the FC-bridge included (check this to be sure). Otherwise you need to buy these: http://www.frozencpu.com/products/24673/ex-blc-1749/EK_FC_Bridge_Link_CSQ_-_Acetal_TOP_Acetal_-_FC_Link_Sys.html#blank
https://linustechtips.com/topic/224938-water-cooling-sli/#findComment-3085616
so a compression leads into the bridge then the birdge distributes the water to both cards then i need a compression for the out of the bridge?
https://linustechtips.com/topic/224938-water-cooling-sli/#findComment-3085641
