BF3 Help
matto97
I have been playing BF3 on FULL settings for about a hole year now at about 25-30FPS suddenly the past 2 weeks i cant even play on low at 20FPS i have tried every thing, any way to fix it please
Desktop: CPU: I7-5820K GPU: 980Ti, 750Ti PhysX Mobo: MSI X99A SLI PLUS RAM: 4x4 Kingston DDR4 2400MHz OS: Win10
Storage: 250GB Samsung Evo, 3TB WD Black and Green FIRESTRIKE, Reason for dedicated PhysX Card.
Peripherals: Screen: 3x BenQ VZ2350 Mouse: Razer Naga Keyboard: Some Dell Thing Sound: Razer Tiamat, 5.1 Logitech Surround Speakers
did the reso change? or are you playing on 64 player matches? the more players the more to process. Were you OCed?
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
same rez but i have never had a problem like this befor weather its 4 players or 64
have you tried reinstalling bf3 or updating you drivers? also whats your specs?
no its fine no other games have any truble
yes tride updating
12GB RAM
AMD A8-4500M
HD 7640G + 7670M
and windows 8 :P
Just abit laggy on the servers maybe?
CPU: i5 3570k                                 PSU: CX650 Corsair                 SSD: 128GB Samsung 840
RAM: 16GB Corsair Vengeance     Case: Zalman Z11                    HDD: 500Gb Toshiba & 1TB Western Digital
MOBO: ASrock Extreme 4 Z77        GPU: GTX 770
i never play on servers with a higher ping then 100
yea, whats the server ping and your ping
i never play on a server with more then 100ping and i do the same for me never over 100
would over clocks be stuffing with it maby?
my suggestion: don't play BF3 at that FPS range. drop to medium or even low to get 45-60 fps. it'll actually look better and play easier than if you play with 25 fps and high settings.
I found it weird that my 7870 can push 130 fps in BF3 at medium and only 80 in BFBC2 on low. at high/ultra it still pushes 60 in both though.
Daily Driver:
Case: Red Prodigy CPU: i5 3570K @ 4.3 GHZ GPU: Powercolor PCS+ 290x @1100 mhz MOBO: Asus P8Z77-I CPU Cooler: NZXT x40 RAM: 8GB 2133mhz AMD Gamer series Storage: A 1TB WD Blue, a 500GB WD Blue, a Samsung 840 EVO 250GB
no i used to play at full setings at about 30-35 FPS and the past 2 weeks i havent been able to do that im now playing at all low settings at 15-25 FPS thats my problem
How much stuff have you installed over the past for months, more processes on the ram means slower jobs.
Listen if you care.
well i did reset my comp last week mainly to see if it would fix my problem but it didnt the problem stayed
